при вигрузке скетча дает ошибку
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino: In function 'void setup()':
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:34:19: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:35:18: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino: In function 'void loop()':
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:45:23: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:47:18: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:48:18: error: expected primary-expression before '.' token
Compilation error: exit status 1
вот код
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define outPin 8
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
unsigned long last_time2;
int seconds = 0;
int minutes = 0;
int hours = 0;
int days = 0;
float start_temp = 0;
float start_hum = 0;
lcd.begin(16, 2);
lcd.backlight();
lcd.clear();
start_temp = DHT.temperature;
start_hum = DHT.humidity;
timer();
if (millis()- last_time2 > 1000){
last_time2 = millis();
int readData = DHT.read11(outPin);
float t = DHT.temperature;
float h = DHT.humidity;
lcd.begin(16, 2);
lcd.print(start_temp);
lcd.print("C");
lcd.print(start_hum);
lcd.print(" H");
lcd.setCursor(0,2);
lcd.print(t);
lcd.print("C ");
lcd.print(h);
lcd.print("H%");
lcd.clear();
void timer(){
seconds = seconds + 1;
if (seconds == 60){
seconds = 0;
minutes = minutes + 1;
if (minutes == 60){
minutes = 0;
hours = hours + 1;
if (hours == 24){
hours = 0;
days = days + 1;
Неужели так тяжело посмотреть хотя бы примеры идущие с библиотекой если уже лень поискать в гугле который завален кодами для dht11 ?
в военное время хрустальные шары запрещены
переделал код, не виводет нормально текст на lcd1602 ic2
не виводит темературу с влажностью сейчас
#include "DHT.h"
#include <Wire.h>
#define DHTPIN 3
float start_temp = 10;
float start_hum = 10;
float h;
float t;
lcd.begin(16, 2);
dht.begin();
lcd.backlight();
lcd.clear();
h = dht.readHumidity();
t = dht.readTemperature();
start_temp = t;
start_hum = h;
if (millis()- last_time2 > 2000){
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
if (isnan(h) || isnan(t)) {
lcd.begin(16, 2);
lcd.print("ERROR");
return;
lcd.print("C ");
lcd.print("% H ");
lcd.setCursor(0,2);
lcd.print(t);
lcd.print("C ");
lcd.print(h);
lcd.print("% H ");
}Остання редакція Cheburek (2022-05-29 15:02:06)
А стандартный Hello world! уже выводил?
Ты здешнему Malyhin-у не родственник случайно? Тот тоже при каждом выводе на дисплей инициализирует его заново и с номерами строк экрана разобраться не может
пересекались
Ну, тогда держи, изучайте https://wokwi.com/projects/332994822216352338
Не во всех библиотеках авторы предусмотрели есть защита от неучей
