#1 2022-05-28 12:49:33
Cheburek
Зареєстрований: 2022-05-17
не работает
при вигрузке скетча дает ошибку
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino: In function 'void setup()':
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:34:19: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:35:18: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino: In function 'void loop()':
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:45:23: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:47:18: error: expected primary-expression before '.' token
D:UserDatamikeOneDriveДокументыArduinosketch_may28asketch_may28a.ino:48:18: error: expected primary-expression before '.' token
Compilation error: exit status 1
вот код
#include <DHT.h>
#include <DHT_U.h>
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define outPin 8
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
unsigned long last_time2;
int seconds = 0;
int minutes = 0;
int hours = 0;
int days = 0;
float start_temp = 0;
float start_hum = 0;
  lcd.begin(16, 2);
	lcd.backlight();
	lcd.clear();
  start_temp = DHT.temperature;
  start_hum = DHT.humidity;
  timer();
  if (millis()- last_time2 > 1000){
    last_time2 = millis();
    int readData = DHT.read11(outPin);
    float t = DHT.temperature;
    float h = DHT.humidity;
    lcd.begin(16, 2);
    lcd.print(start_temp);
    lcd.print("C");
    lcd.print(start_hum);
    lcd.print(" H");
    lcd.setCursor(0,2);
    lcd.print(t);
    lcd.print("C ");
    lcd.print(h);
    lcd.print("H%");
    lcd.clear();
void timer(){
    seconds = seconds + 1;
  if (seconds == 60){
    seconds = 0;
    minutes = minutes + 1;
  if (minutes == 60){
    minutes = 0;
    hours = hours + 1;
  if (hours == 24){
    hours = 0;
    days = days + 1;
#2 2022-05-28 14:58:29
vvr
Зареєстрований: 2015-04-12
Re: не работает
Переведите сообщение об ошибке.
Узнаете много интересного.
Можно его загуглить...
#3 2022-05-29 14:18:40
Cheburek
Re: не работает
перевел загуглил, ничего не нашел
#4 2022-05-29 14:25:22
г0сть
Гість
Re: не работает
Неужели так тяжело посмотреть хотя бы примеры идущие с библиотекой если уже лень поискать в гугле который завален кодами для dht11 ?
#5 2022-05-29 14:27:03
Cheburek
Re: не работает
посмотрел, скопировал, ошибка уже другая
#6 2022-05-29 14:35:23
г0сть
Гість
Re: не работает
в военное время хрустальные шары запрещены
#7 2022-05-29 14:36:52
Cheburek
Re: не работает
от блин, а я себе один заказал
#8 2022-05-29 14:53:17
Cheburek
Re: не работает
переделал код, не виводет нормально текст на lcd1602 ic2
не виводит темературу с влажностью сейчас
#include "DHT.h"
#include <Wire.h>
#define DHTPIN 3
float start_temp = 10;
float start_hum = 10;
float h;
float t;
  lcd.begin(16, 2);
  dht.begin();
  lcd.backlight();
  lcd.clear();
  h = dht.readHumidity();
  t = dht.readTemperature();
  start_temp = t;
  start_hum = h;
  if (millis()- last_time2 > 2000){
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    if (isnan(h) || isnan(t)) {
      lcd.begin(16, 2);
      lcd.print("ERROR");
      return;
    lcd.print("C ");
    lcd.print("% H ");
    lcd.setCursor(0,2);
    lcd.print(t);
    lcd.print("C ");
    lcd.print(h);
    lcd.print("% H ");
Остання редакція Cheburek (2022-05-29 15:02:06)
#9 2022-05-29 15:07:17
г0сть
Гість
Re: не работает
А стандартный Hello world! уже выводил?
#10 2022-05-29 15:20:15
Cheburek
Re: не работает
да
#11 2022-05-29 15:27:39
u0cnm
Гість
Re: не работает
Ты здешнему Malyhin-у не родственник случайно? Тот тоже при каждом выводе на дисплей инициализирует его заново и с номерами строк экрана разобраться не может
#12 2022-05-29 15:38:13
Cheburek
Re: не работает
родственик, а что? знакоми
#13 2022-05-29 15:40:17
г0сть
Гість
Re: не работает
пересекались
#14 2022-05-29 15:47:39
Cheburek
Re: не работает
нет, делаем один проект вместе
#15 2022-05-29 15:56:07
г0сть
Гість
Re: не работает
Ну, тогда держи, изучайте https://wokwi.com/projects/332994822216352338
Не во всех библиотеках авторы предусмотрели есть защита от неучей
