follow JBS 2016-05-30 18:40:28
http://forum.arduino.ua/viewtopic.php?pid=3515#p3515
pcb he made with violations of protection , but it's better than the original )
PT VIP 3AC/380 03 Rev. 2 ?
all the boards are different, you need to make a correct connection
Остання редакція NoName (2016-09-14 12:44:02)
The connector to MB is with 5 wires. On S1 appears 6 wires.
http://forum.arduino.ua/img/members/109 … 05_13.jpeg
http://forum.arduino.ua/img/members/109 … 06_44.jpeg
Остання редакція neckro (2016-09-14 18:16:09)
you should have the skills to reverse engineering (
or use the help of your friend
martinways Epson EB-W22
neckro Sanyo PLC-XE31
maybe similar, but are different devices
NoName, thank you again for you answer. I followed your advice, and i have started to dig So far, i have found the pins order from http://cncms.com.au/SANYO-SMs/Commercia … e31_sm.pdf (Service Manual) on page 78.
K8H: pin 1 LAMP_SENS , PIN 2 GND, PIN 3 5V, PIN 4 LAMP_SW, PIN 5 ECO. Witch one from those will be TX and RX ?
Good day,
My code it work, and I don't change nothing in drop box source. But take care on optocuplers interface with mainboard. Here are main big mistakes and this is the reason that code don't work.
Try to copy the original ballast circuit from optocuplers to MCU.
Regards,
Ионуц
Hello. Until the Saleae will arrive, i have dig more on internet and i have found Standardized UART Protocol and is helping me to understand some things As i see, for me:
Ballast 3AC/380 O3 Rev. 2
case 0x00: Serial.write(0x00); break; //echo
case 0x70: Serial.write(0x70); break; // Enable comnication
case 0xF0: Serial.write(0xF0); Serial.write(0x01); break;// Company ID , default is 01
case 0xF1: Serial.write(0xF1); Serial.write(0x0C); Serial.write(0x07);; break; // F1h + hardware ID + software ID = as table, 0Ch | as software ID i haven`t figure out yet.
case 0xF3: Serial.write(0xF3); Serial.write(0x00); break; // waveform 00 is default as table 3
case 0xF2: Serial.write(0xF3); Serial.write(0x64); break; // ??
case 0xF4: Serial.write(0xF4); Serial.write(0x80); break; // This query returns the single byte value of the actual waveform gain, which has been set with the command
“Set Gain” (for gain calculation formula, see section 2.2.1.7 “Set Gain (72h)”). Can i set gain ???
case 0xF6: Serial.write(0xF6); Serial.write(0x02); break; // This query returns a single byte, representing the total number of waveforms stored in the lamp driver. This can represent projector resolutions?
case 0xFA: Serial.write(0xFA); Serial.write(0x60); break; // This query returns the minimum allowed gain value for the lamp. (for gain calculation formula, see section
2.2.1.7 “Set Gain (72h)”) Again, can i set gain?
case 0xFB: Serial.write(0xFB); Serial.write(0x80); break; // This query returns the maximum allowed gain value for the lamp. (for gain calculation formula, see section
2.2.1.7 “Set Gain (72h)”) ....
case 0xF5: Serial.write(0xF5); Serial.write(0x01); break; // This query returns a single byte, status of the ballast. Table 12 defines the bits of the ballast status
register. Lamp on represent 0.
Even so, is not working yet. Having the pdf above, and using a lcd on arduino, those values can`t be readed from mainboard?
"Even so, is not working yet. Having the pdf above, and using a lcd on arduino, those values can`t be readed from mainboard?"
yes of course, but it's better to send data directly to a pc for analysis.
LСD uncomfortable
terminal with two UART
https://www.dropbox.com/s/6k17snx6ep6t1 … 6.zip?dl=0
my exapmle
11.007754000000000,Async Serial,A (0x41)
11.010652000000000,Async Serial,O (0x4F)
11.014524000000000,Async Serial,'160' (0xA0)
11.017143500000000,Async Serial,'160' (0xA0)
11.019732500000000,Async Serial,'156' (0x9C)
11.022526500000000,Async Serial,'158' (0x9E)
11.025045000000000,Async Serial,D (0x44)
11.027632499999999,Async Serial,'134' (0x86)
11.030253500000001,Async Serial,'142' (0x8E)
11.032545499999999,Async Serial,'16' (0x10)
11.039941499999999,Async Serial,'195' (0xC3)
11.042764999999999,Async Serial,'166' (0xA6)
11.644226500000000,Async Serial,A (0x41)
11.646779499999999,Async Serial,O (0x4F)
11.649330500000000,Async Serial,'202' (0xCA)
11.652136000000000,Async Serial,'12' (0x0C)
12.657062500000000,Async Serial,A (0x41)
12.659765999999999,Async Serial,N (0x4E)
12.662478999999999,Async Serial,'202' (0xCA)
if Arduino has three ports, yes
1 - in a transparent mode, that received, the sent
2. two inputs line (RX) to the control mode
but, Im use the oscilloscope/logic analyzer
vvr, и не очень то и бурная, я за всех отдуваюсь, присоединяйтесь ), ибо чукча читатель ) и совсем не писатель
для примера, мои немцы мало говорят по английски, недотягивают до fluent, я тем более %(, но ет ведь не повод отказать в помощи ),
Hi, Saleae has arrived today, but the projectors is broken. I have get all parts together and is not starting anymore even with original ballast. Maybe, i have broke it with arduino?
Остання редакція neckro (2016-09-22 21:00:20)
The connector was 1 2 3 4 5 to 5 4 3 2 1 Now the measurement part. I will keep update this post
Update. I got some data but too many frame errors. Is that normal?
Остання редакція neckro (2016-09-23 00:20:38)
I have made another measurement and got the following data. The measurement is made only on pin 5 on CH0, because if i connect pin 1 to CH1, the projector the lamp turn off after few seconds and projector is keep rebooting.
How much i try, pin 1 is causing reboot. Even if is single connected on Saleae.
Остання редакція neckro (2016-09-24 20:20:31)
I finally got some data. 1Mohm resistor between pin1 and Saleae saved the day
The projector is not rebooting anymore and got the following data on 50khz:
Time (s) Analyzer Name Decoded Protocol Result
1.30964 Async Serial '127' (0x7F)
1.31224 Async Serial '255' (0xFF) (parity error)
1.3134 Async Serial '255' (0xFF) (framing error & parity error)
1.3146 Async Serial '255' (0xFF) (parity error)
1.31606 Async Serial '255' (0xFF) (parity error)
1.31722 Async Serial '255' (0xFF) (parity error)
1.31864 Async Serial '175' (0xAF)
1.31978 Async Serial '255' (0xFF) (parity error)
1.321 Async Serial '251' (0xFB)
1.32214 Async Serial '255' (0xFF) (parity error)
1.32326 Async Serial '255' (0xFF) (parity error)
1.32442 Async Serial '255' (0xFF) (parity error)
1.32568 Async Serial '255' (0xFF) (parity error)
1.32692 Async Serial '255' (0xFF) (parity error)
1.32808 Async Serial '255' (0xFF) (parity error)
1.32922 Async Serial '255' (0xFF) (parity error)
1.33038 Async Serial '255' (0xFF) (parity error)
1.33218 Async Serial '255' (0xFF)
1.33342 Async Serial '255' (0xFF) (parity error)
1.33534 Async Serial '255' (0xFF) (parity error)
1.33668 Async Serial '255' (0xFF) (parity error)
1.33778 Async Serial '255' (0xFF)
1.33962 Async Serial '254' (0xFE)
1.34202 Async Serial '247' (0xF7)
1.3439 Async Serial '255' (0xFF) (parity error)
1.35394 Async Serial '255' (0xFF) (parity error)
1.3559 Async Serial '255' (0xFF) (parity error)
1.36178 Async Serial '255' (0xFF) (parity error)
1.4138 Async Serial '255' (0xFF) (parity error)
1.57338 Async Serial '255' (0xFF) (parity error)
1.57482 Async Serial '255' (0xFF) (parity error)
1.57698 Async Serial '239' (0xEF)
1.57808 Async Serial '255' (0xFF) (parity error)
1.57918 Async Serial '255' (0xFF) (parity error)
1.58198 Async Serial '255' (0xFF) (parity error)
1.5841 Async Serial '255' (0xFF) (parity error)
1.58552 Async Serial '255' (0xFF) (parity error)
1.68722 Async Serial '255' (0xFF) (parity error)
1.69312 Async Serial '255' (0xFF) (parity error)
1.69426 Async Serial '255' (0xFF) (parity error)
1.69562 Async Serial '255' (0xFF) (parity error)
1.69684 Async Serial '251' (0xFB)
1.80872 Async Serial '239' (0xEF)
1.80984 Async Serial '255' (0xFF) (parity error)
1.81102 Async Serial '255' (0xFF) (parity error)
1.81218 Async Serial '255' (0xFF) (parity error)
1.81332 Async Serial '247' (0xF7)
1.81446 Async Serial '255' (0xFF) (parity error)
1.81592 Async Serial '255' (0xFF) (parity error)
1.81704 Async Serial '237' (0xED) (parity error)
1.81862 Async Serial '255' (0xFF) (parity error)
1.91102 Async Serial '255' (0xFF) (parity error)
1.91292 Async Serial '255' (0xFF) (parity error)
1.91444 Async Serial '255' (0xFF) (parity error)
1.91558 Async Serial '255' (0xFF) (parity error)
1.9173 Async Serial '255' (0xFF) (parity error)
1.95572 Async Serial '255' (0xFF)
1.95782 Async Serial '255' (0xFF) (parity error)
1.96036 Async Serial '255' (0xFF) (parity error)
1.96272 Async Serial '255' (0xFF) (parity error)
1.96386 Async Serial '255' (0xFF) (parity error)
1.96502 Async Serial '255' (0xFF) (parity error)
1.96702 Async Serial '255' (0xFF) (parity error)
3.4185 Async Serial '255' (0xFF) (parity error)
3.4298 Async Serial '223' (0xDF)
3.43266 Async Serial '255' (0xFF) (parity error)
3.4351 Async Serial '238' (0xEE) (parity error)
3.4362 Async Serial '255' (0xFF) (parity error)
3.43742 Async Serial '255' (0xFF) (parity error)
3.4412 Async Serial '255' (0xFF) (parity error)
3.44254 Async Serial '255' (0xFF) (parity error)
3.44404 Async Serial '255' (0xFF) (parity error)
3.44518 Async Serial '255' (0xFF) (parity error)
3.4515 Async Serial '255' (0xFF) (parity error)
3.45334 Async Serial '255' (0xFF) (parity error)
3.46424 Async Serial '255' (0xFF) (parity error)
3.47786 Async Serial '255' (0xFF) (parity error)
3.48394 Async Serial '255' (0xFF) (parity error)
3.49758 Async Serial '255' (0xFF) (parity error)
3.53632 Async Serial '255' (0xFF) (parity error)
3.54132 Async Serial '255' (0xFF) (parity error)
Остання редакція neckro (2016-10-17 00:15:43)
And the measurement on 25khz:
2.9616 Async Serial '255' (0xFF) (parity error)
2.96508 Async Serial '223' (0xDF)
2.96896 Async Serial '255' (0xFF) (parity error)
2.97124 Async Serial '183' (0xB7) (framing error & parity error)
2.97264 Async Serial '223' (0xDF)
2.9738 Async Serial '223' (0xDF)
2.97524 Async Serial '255' (0xFF) (parity error)
2.97636 Async Serial ~ (0x7E) (parity error)
2.97752 Async Serial '255' (0xFF)
2.97868 Async Serial '127' (0x7F) (framing error)
2.97996 Async Serial '255' (0xFF) (parity error)
2.98108 Async Serial '255' (0xFF) (parity error)
2.98232 Async Serial '214' (0xD6) (parity error)
2.9836 Async Serial 6 (0x36) (parity error)
2.9848 Async Serial '231' (0xE7) (parity error)
2.9874 Async Serial '255' (0xFF) (parity error)
2.99436 Async Serial '255' (0xFF) (parity error)
2.99696 Async Serial '255' (0xFF) (parity error)
2.99852 Async Serial '255' (0xFF) (parity error)
3.0006 Async Serial '255' (0xFF) (parity error)
3.00184 Async Serial '255' (0xFF) (parity error)
3.0036 Async Serial '255' (0xFF) (parity error)
3.00476 Async Serial '255' (0xFF) (parity error)
3.23612 Async Serial '255' (0xFF) (parity error)
3.23908 Async Serial '239' (0xEF)
3.24164 Async Serial '255' (0xFF) (parity error)
3.24308 Async Serial '239' (0xEF)
3.2442 Async Serial '255' (0xFF) (parity error)
3.24532 Async Serial '127' (0x7F)
3.24676 Async Serial '127' (0x7F)
3.24792 Async Serial '255' (0xFF) (parity error)
3.44788 Async Serial '255' (0xFF) (parity error)
3.45496 Async Serial '239' (0xEF)
3.45628 Async Serial '254' (0xFE)
3.45768 Async Serial '255' (0xFF) (parity error)
3.6198 Async Serial '239' (0xEF)
3.62812 Async Serial '255' (0xFF) (parity error)
5.36648 Async Serial '255' (0xFF) (parity error)
5.3816 Async Serial '255' (0xFF) (parity error)
5.49696 Async Serial '255' (0xFF) (parity error)
5.51464 Async Serial '255' (0xFF) (parity error)
5.57636 Async Serial '255' (0xFF) (parity error)
hello neckro
its not right
pls, give the file with raw data ( .logicdata )
"1Mohm resistor between pin1 and Saleae saved the day" - сongratulations )
World First! DIY Real 4k (UHD) Beam Projector
http://www.instructables.com/id/World-First-DIY-Real-4k-UHD-Beam-Projector/?utm_source=newsletter&utm_medium=email
