Указал плату LGT Nano ... все равно ....
Arduino: 1.8.5 (Windows 7), Плата:"LGT Nano"
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0x07:m -Uhfuse:w:0xff:m -Ulfuse:w:0xff:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM5
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x07"
avrdude: writing efuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.11s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x07:
avrdude: load data efuse data from input file 0x07:
avrdude: input file 0x07 contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.00s
avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xff instead of 0x07 (double check with your datasheet first).
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xff"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xff:
avrdude: load data hfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8p\optiboot_lgt8f328p.hex:i -Ulock:w:0x3f:m
Using Port : COM5
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8p\optiboot_lgt8f328p.hex"
avrdude: writing flash (30720 bytes):
Writing | ################################################## | 100% 0.56s
avrdude: 30720 bytes of flash written
avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8p\optiboot_lgt8f328p.hex:
avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8p\optiboot_lgt8f328p.hex:
avrdude: input file C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8p\optiboot_lgt8f328p.hex contains 30720 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.09s
avrdude: verification error, first mismatch at byte 0x0000
0x8c != 0x0c
avrdude: verification error; content mismatch
Ошибка при записи загрузчика.
Оказывается моя эпопея не завершена...
Продавец прислал новые платы !!!!
Пока не рискнул их подключать, хочу уточнить, может действительно я упустил какой то нюанс...
Поэтому обращаюсь к тем у кого процесс пошел...
Всели правильно я делал ?
1 - использовал переходник CP2102 USB 2.0 TTL UART
https://ru.aliexpress.com/item/1PCS-CP2 … autifyAB=0
2 - заливал стандартный "блинк" из примеров.
3 - производил настройки как описано тут https://arduinoplus.ru/wemos-xi/
the devil is in the details
Остання редакція renoshnik (2018-07-03 15:42:03)
В ардуинке стоит конденсатор между DTR и RESET.
Сначала нужно сказать есть ли загрузчик.
Пока не известно, новые платы еще не распечатывал.
Есть опасение, что в первый раз я затер загрузчик т.к. было несколько ярких вспышек СД, а потом в полнакала стал светить.
Ну и... Всё класс?)
Я со своими приключениями уже на холодную воду дую...
Уже подозреваю, может ЮСБ УАРТ переходник не той модели .... может действительно заказать на CH340G ???
)) Так через Вемос должна ведь грузить...
Мне ещё одна похожая плата попалась, правда с LGT8F328е. И даже загрузилась через стандартную Нано, только работала не правильно.)
Остання редакція Green (2018-07-06 09:44:08)
Так и грузил "блинк" через Вемос (выбрал в боардс), а ничего не получилось...
Какой переходник USB-UART вы использовали ?
!!!! появился прорыв !!!!
Купил arduino nano подключил как обычно, результат = ошибка ...
От нечего делать (от безисходности) питание "вемоса" кинул на +3.3 у "ардуины" ...
И вот получил !!!
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0x07:m -Uhfuse:w:0xff:m -Ulfuse:w:0xff:m
Using Port : COM6
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
Writing | ################################################## | 100% 0.02s
################################################## | 100% 0.12s
Reading | ################################################## | 100% -0.00s
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM6 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8e\optiboot_lgt8f328d.hex:i -Ulock:w:0x3f:m
Using Port : COM6
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8e\optiboot_lgt8f328d.hex"
Writing | ################################################## | 100% 0.16s
avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8e\optiboot_lgt8f328d.hex:
avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8e\optiboot_lgt8f328d.hex:
avrdude: input file C:\Program Files (x86)\Arduino\hardware\wemos\XI/bootloaders/lgt8fx8e\optiboot_lgt8f328d.hex contains 30720 bytes
Reading | ################################################## | 100% 0.08s
avrdude: 30720 bytes of flash verified
Что бы это значило ... ?
Залил "блинк" !!!
Скетч залился только при питании 3,3 Вольта в дальнейшем переключил питание на 5 Вольт скетч работает ...
Если заливать скетч при питании 5 Вольт, плата виснет ....
актуальный вопрос - какое опорное напряжение для АЦП ?
... актуальный вопрос - какое опорное напряжение для АЦП ?
Такое же как и у Мег.
renoshnik пише:... актуальный вопрос - какое опорное напряжение для АЦП ?
Тоесть 5 Вольт.
Кто-то может объяснить эту странность с питанием при заливке скетча ?
Переходник какой непопадя.) Кажись от телефона Ериксон.)
Причём АЦП к заливке скетча?
Тоесть 5 Вольт. Кто-то может объяснить эту странность с питанием при заливке скетча ?
Точнее три: VCCA, VREFexternal, VREFinternal(1.2V). А странность можно объяснить только с помощью хрустального шара или технологического исследования.
renoshnik пише:Тоесть 5 Вольт. Кто-то может объяснить эту странность с питанием при заливке скетча ?
... тут оказывается все гораздо хитрее... восток дело тонкое ....
C:\Program Files (x86)\Arduino\hardware\wemos\XI\cores\lgt8f\wiring_analog.c
wiring_analog.c - analog input and output
Part of Arduino - http://www.arduino.cc/
Copyright (c) 2005-2006 David A. Mellis
This library is free software; you can redistribute it and/or
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General
Public License along with this library; if not, write to the
Free Software Foundation, Inc., 59 Temple Place, Suite 330,
Boston, MA 02111-1307 USA
Modified 28 September 2010 by Mark Sproul
$Id: wiring.c 248 2007-02-03 15:36:30Z mellis $
#include "wiring_private.h"
#include "pins_arduino.h"
uint8_t analog_resbit = 0;
uint8_t analog_resdir = 0;
uint8_t analog_reference = DEFAULT;
#if defined(__LGT8F__)
void analogReadResolution(uint8_t res)
if(res > 16) res = 16;
if(res > 12) {
analog_resbit = res - 12;
analog_resdir = 0;
analog_resbit = 12 - res;
analog_resdir = 1;
#endif
void analogReference(uint8_t mode)
// can't actually set the register here because the default setting
// will connect AVCC and the AREF pin, which would cause a short if
// there's something connected to AREF.
analog_reference = mode;
#if defined(__LGT8FX8E__) || defined(__LGT8FX8P__)
if(analog_reference == INTERNAL2V56) {
VCAL = VCAL2;
VCAL = VCAL1;
#else
// set analog reference for ADC/DAC
if(analog_reference == EXTERNAL) {
DACON = (DACON & 0x0C) | 0x1;
if((PMX2 & 0x2) == 0x2) {
GPIOR0 = PMX2 & 0xfd;
PMX2 = 0x80;
PMX2 = GPIOR0;
} else if(analog_reference == DEFAULT) {
DACON &= 0x0C;
DACON = (DACON & 0x0C) | 0x2;
cbi(ADCSRD, REFS2);
if(analog_reference == INTERNAL2V048) {
VCAL = VCAL2; // 2.048V
} else if(analog_reference == INTERNAL4V096) {
sbi(ADCSRD, REFS2);
VCAL = VCAL3; // 4.096V
VCAL = VCAL1; // 1.024V
#endif
ADMUX = (analog_reference << 6);
#endif
static uint16_t adcRead()
volatile uint8_t tmp = 0;
// start the conversion
sbi(ADCSRA, ADSC);
// ADSC is cleared when the conversion finishes
while (bit_is_set(ADCSRA, ADSC));
// read low byte firstly to cause high byte lock.
tmp = ADCL;
return (ADCH << 8) | tmp;
int __analogRead(uint8_t pin)
uint16_t pVal;
#if defined(__LGT8FX8P__)
uint16_t nVal;
// enable/disable internal 1/5VCC channel
ADCSRD &= 0xf0;
if(pin == V5D1 || pin == V5D4) {
ADCSRD |= 0x06;
#endif
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
if (pin >= 54) pin -= 54; // allow for channel or pin numbers
#elif defined(__AVR_ATmega32U4__)
if (pin >= 18) pin -= 18; // allow for channel or pin numbers
#elif defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega644__) || defined(__AVR_ATmega644A__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644PA__)
if (pin >= 24) pin -= 24; // allow for channel or pin numbers
#elif defined(analogPinToChannel) && (defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__))
pin = analogPinToChannel(pin);
#else
if (pin >= 14) pin -= 14; // allow for channel or pin numbers
#endif
#if defined(__AVR_ATmega32U4__)
ADCSRB = (ADCSRB & ~(1 << MUX5)) | (((pin >> 3) & 0x01) << MUX5);
#elif defined(ADCSRB) && defined(MUX5)
// the MUX5 bit of ADCSRB selects whether we're reading from channels
// 0 to 7 (MUX5 low) or 8 to 15 (MUX5 high).
#endif
// set the analog reference (high two bits of ADMUX) and select the
// channel (low 4 bits). this also sets ADLAR (left-adjust result)
// to 0 (the default).
#if defined(ADMUX)
ADMUX = (analog_reference << 6) | (pin & 0x1f);
#endif
// without a delay, we seem to read from the wrong channel
//delay(1);
#if defined(ADCSRA) && defined(ADCL)
sbi(ADCSRC, SPN);
nVal = adcRead();
cbi(ADCSRC, SPN);
#endif
pVal = adcRead();
pVal = (pVal + nVal) >> 1;
#endif
#else
// we dont have an ADC, return 0
pVal = 0;
#endif
// gain-error correction
pVal -= (pVal >> 5);
#elif defined(__LGT8FX8P__)
pVal -= (pVal >> 7);
#endif
// standard device from atmel
return pVal;
int analogRead(uint8_t pin)
if(analog_resbit == 0)
return __analogRead(pin);
if(analog_resdir == 1) {
return __analogRead(pin) >> analog_resbit;
return __analogRead(pin) << analog_resbit;
#else
#endif
// Right now, PWM output only works on the pins with
// hardware support. These are defined in the appropriate
// pins_*.c file. For the rest of the pins, we default
// to digital output.
void analogWrite(uint8_t pin, int val)
// We need to make sure the PWM output is enabled for those pins
// that support it, as we turn it off when digitally reading or
// writing with them. Also, make sure the pin is in output mode
// for consistenty with Wiring, which doesn't require a pinMode
// call for the analog output pins.
if(LGT_NOT_DACO(pin)) {
pinMode(pin, OUTPUT);
if (val == 0 && LGT_NOT_DACO(pin)) {
digitalWrite(pin, LOW);
} else if (val == 255 && LGT_NOT_DACO(pin)) {
digitalWrite(pin, HIGH);
switch(digitalPinToTimer(pin)) {
// XXX fix needed for atmega8
#if defined(TCCR0) && defined(COM00) && !defined(__AVR_ATmega8__)
case TIMER0A:
// connect pwm to pin on timer 0
sbi(TCCR0, COM00);
OCR0 = val; // set pwm duty
#endif
#if defined(TCCR0A) && defined(COM0A1)
case TIMER0A:
// connect pwm to pin on timer 0, channel A
sbi(TCCR0A, COM0A1);
OCR0A = val; // set pwm duty
#endif
#if defined(TCCR0A) && defined(COM0B1)
case TIMER0B:
// connect pwm to pin on timer 0, channel B
sbi(TCCR0A, COM0B1);
OCR0B = val; // set pwm duty
#endif
#if defined(TCCR1A) && defined(COM1A1)
case TIMER1A:
// connect pwm to pin on timer 1, channel A
sbi(TCCR1A, COM1A1);
OCR1A = val; // set pwm duty
#endif
#if defined(TCCR1A) && defined(COM1B1)
case TIMER1B:
// connect pwm to pin on timer 1, channel B
sbi(TCCR1A, COM1B1);
OCR1B = val; // set pwm duty
#endif
#if defined(TCCR2) && defined(COM21)
case TIMER2:
// connect pwm to pin on timer 2
sbi(TCCR2, COM21);
OCR2 = val; // set pwm duty
#endif
#if defined(TCCR2A) && defined(COM2A1)
case TIMER2A:
// connect pwm to pin on timer 2, channel A
sbi(TCCR2A, COM2A1);
OCR2A = val; // set pwm duty
#endif
#if defined(TCCR2A) && defined(COM2B1)
case TIMER2B:
// connect pwm to pin on timer 2, channel B
sbi(TCCR2A, COM2B1);
OCR2B = val; // set pwm duty
#endif
#if defined(TCCR3A) && defined(COM3A1)
case TIMER3A:
// connect pwm to pin on timer 3, channel A
sbi(TCCR3A, COM3A1);
OCR3A = val; // set pwm duty
#endif
#if defined(TCCR3A) && defined(COM3B1)
case TIMER3B:
// connect pwm to pin on timer 3, channel B
sbi(TCCR3A, COM3B1);
OCR3B = val; // set pwm duty
#endif
#if defined(TCCR3A) && defined(COM3C1)
case TIMER3C:
// connect pwm to pin on timer 3, channel C
sbi(TCCR3A, COM3C1);
OCR3C = val; // set pwm duty
#endif
#if defined(TCCR4A)
case TIMER4A:
//connect pwm to pin on timer 4, channel A
sbi(TCCR4A, COM4A1);
#if defined(COM4A0) // only used on 32U4
cbi(TCCR4A, COM4A0);
#endif
OCR4A = val; // set pwm duty
#endif
#if defined(TCCR4A) && defined(COM4B1)
case TIMER4B:
// connect pwm to pin on timer 4, channel B
sbi(TCCR4A, COM4B1);
OCR4B = val; // set pwm duty
#endif
#if defined(TCCR4A) && defined(COM4C1)
case TIMER4C:
// connect pwm to pin on timer 4, channel C
sbi(TCCR4A, COM4C1);
OCR4C = val; // set pwm duty
#endif
#if defined(TCCR4C) && defined(COM4D1)
case TIMER4D:
// connect pwm to pin on timer 4, channel D
sbi(TCCR4C, COM4D1);
#if defined(COM4D0) // only used on 32U4
cbi(TCCR4C, COM4D0);
#endif
OCR4D = val; // set pwm duty
#endif
#if defined(TCCR5A) && defined(COM5A1)
case TIMER5A:
// connect pwm to pin on timer 5, channel A
sbi(TCCR5A, COM5A1);
OCR5A = val; // set pwm duty
#endif
#if defined(TCCR5A) && defined(COM5B1)
case TIMER5B:
// connect pwm to pin on timer 5, channel B
sbi(TCCR5A, COM5B1);
OCR5B = val; // set pwm duty
#endif
#if defined(TCCR5A) && defined(COM5C1)
case TIMER5C:
// connect pwm to pin on timer 5, channel C
sbi(TCCR5A, COM5C1);
OCR5C = val; // set pwm duty
#endif
case LGTDAO0:
DAL0 = val;
#endif
case LGTDAO1:
DAL1 = val;
#endif
case NOT_ON_TIMER:
default:
if (val < 128) {
получается :
INTERNAL2V56 // 2.56V
INTERNAL2V048 // 2.048V
INTERNAL4V096 // 4.096V
а еще тут есть analogReadResolution(uint8_t res)
Тоньше не бывает, того и гляди лопнет. У LGT8F88 так я написал. А на LGT8F328G нет документов даже на сайте производителя. Отака дешева рибка.
Вячеслав Азаров пише:Тоньше не бывает, того и гляди лопнет. У LGT8F88 так я написал. А на LGT8F328G нет документов даже на сайте производителя. Отака дешева рибка.
Я его не нашел поисковиком, а по китайски я не читаю. Судя по картинкам вещь очень передовая. Только очень плохо читать. Три опорника - круто! Нужно электрические характеристики посмотреть, что-бы судить об этом. Да поработать, с ними, пол годика.
Я так, мимо проходил, напомнило мне ESP32 - при первом взгляде одни "Вау". А после первого опыта работы "да ну нифиг". Написано одно, а на деле половина не работает.
Я не настоящий сварщик, но мужики рассказывали что при записи в энергонезависимую память у микроконтроллеров к питанию особые требования.
renoshnik пише:Кто-то может объяснить эту странность с питанием при заливке скетча ?
Вот это и настораживает... Если МК работает при питании 5 Вольт, (проверял "блинк" и "аналог рид") то как будет в скетчах с записью/чтением ЕЕПРОМ... ?
Нужно поэкспериментировть....
АЦП по моему действительно = 12 !!!
