Добрый день !!! ПОМОГИТЕ запустить...
Есть вот такая плата https://arduinoplus.ru/wemos-xi/
делал все как написано
  https://uamper.com/плата-разработки-отл … emos-11-xl
В IDE плата появилась
При загрузке пустого скетча выдается ошибка
Arduino: 1.8.5 (Windows 7), Плата:"WEMOS XI"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Admin\AppData\Local\Arduino15\packages -hardware C:\Users\Admin\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Documents\Arduino\libraries -fqbn=wemos:XI:xi -ide-version=10805 -build-path C:\Temp\arduino_build_424490 -warnings=all -build-cache C:\Temp\arduino_cache_917503 -prefs=build.warn_data_percentage=75 -verbose C:\Temp\untitled1167276334.tmp\sketch_apr28a\sketch_apr28a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Admin\AppData\Local\Arduino15\packages -hardware C:\Users\Admin\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Admin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Admin\Documents\Arduino\libraries -fqbn=wemos:XI:xi -ide-version=10805 -build-path C:\Temp\arduino_build_424490 -warnings=all -build-cache C:\Temp\arduino_cache_917503 -prefs=build.warn_data_percentage=75 -verbose C:\Temp\untitled1167276334.tmp\sketch_apr28a\sketch_apr28a.ino
Using board 'xi' from platform in folder: C:\Users\Admin\Documents\Arduino\hardware\wemos\XI
Using core 'lgt8f' from platform in folder: C:\Users\Admin\Documents\Arduino\hardware\wemos\XI
Detecting libraries used...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Temp\arduino_build_424490\sketch\sketch_apr28a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Temp\arduino_build_424490\sketch\sketch_apr28a.ino.cpp" -o "C:\Temp\arduino_build_424490\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Temp\arduino_build_424490\preproc\ctags_target_for_gcc_minus_e.cpp"
Компиляция скетча...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Temp\arduino_build_424490\sketch\sketch_apr28a.ino.cpp" -o "C:\Temp\arduino_build_424490\sketch\sketch_apr28a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\WInterrupts.c" -o "C:\Temp\arduino_build_424490\core\WInterrupts.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\clock.c" -o "C:\Temp\arduino_build_424490\core\clock.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\wiring.c" -o "C:\Temp\arduino_build_424490\core\wiring.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\wiring_analog.c" -o "C:\Temp\arduino_build_424490\core\wiring_analog.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\wiring_digital.c" -o "C:\Temp\arduino_build_424490\core\wiring_digital.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\wiring_pulse.c" -o "C:\Temp\arduino_build_424490\core\wiring_pulse.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\wiring_shift.c" -o "C:\Temp\arduino_build_424490\core\wiring_shift.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\avr-libc\malloc.c" -o "C:\Temp\arduino_build_424490\core\avr-libc\malloc.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\avr-libc\realloc.c" -o "C:\Temp\arduino_build_424490\core\avr-libc\realloc.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\CDC.cpp" -o "C:\Temp\arduino_build_424490\core\CDC.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HID.cpp" -o "C:\Temp\arduino_build_424490\core\HID.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp" -o "C:\Temp\arduino_build_424490\core\HardwareSerial.cpp.o"
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp:98:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   if (i != buffer->tail) {
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp:127:21: warning: unused variable 'c' [-Wunused-variable]
       unsigned char c = UDR0;
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp:368:11: warning: unused variable 'current_config' [-Wunused-variable]
   uint8_t current_config;
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\HardwareSerial.cpp:467:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   while (i == _tx_buffer->tail)
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\IPAddress.cpp" -o "C:\Temp\arduino_build_424490\core\IPAddress.cpp.o"
In file included from C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\IPAddress.cpp:3:0:
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f/IPAddress.h: In member function 'IPAddress::operator uint32_t()':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f/IPAddress.h:51:55: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     operator uint32_t() { return *((uint32_t*)_address); };
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f/IPAddress.h: In member function 'bool IPAddress::operator==(const IPAddress&)':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f/IPAddress.h:52:75: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
     bool operator==(const IPAddress& addr) { return (*((uint32_t*)_address)) == (*((uint32_t*)addr._address)); };
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f/IPAddress.h:52:108: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\Print.cpp" -o "C:\Temp\arduino_build_424490\core\Print.cpp.o"
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\Print.cpp:44:23: warning: '__progmem__' attribute ignored [-Wattributes]
   const char PROGMEM *p = (const char PROGMEM *)ifsh;
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\Stream.cpp" -o "C:\Temp\arduino_build_424490\core\Stream.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\Tone.cpp" -o "C:\Temp\arduino_build_424490\core\Tone.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\USBCore.cpp" -o "C:\Temp\arduino_build_424490\core\USBCore.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\WMath.cpp" -o "C:\Temp\arduino_build_424490\core\WMath.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\WString.cpp" -o "C:\Temp\arduino_build_424490\core\WString.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\main.cpp" -o "C:\Temp\arduino_build_424490\core\main.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-g++" -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_XI   "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f" "-IC:\Users\Admin\Documents\Arduino\hardware\wemos\XI\variants\lgt8fx8e" "C:\Users\Admin\Documents\Arduino\hardware\wemos\XI\cores\lgt8f\new.cpp" -o "C:\Temp\arduino_build_424490\core\new.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\WInterrupts.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\clock.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\wiring.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\wiring_analog.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\wiring_digital.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\wiring_pulse.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\wiring_shift.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\avr-libc\malloc.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\avr-libc\realloc.c.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\CDC.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\HID.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\HardwareSerial.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\IPAddress.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\Print.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\Stream.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\Tone.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\USBCore.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\WMath.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\WString.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\main.cpp.o"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-ar" rcs  "C:\Temp\arduino_build_424490\core\core.a" "C:\Temp\arduino_build_424490\core\new.cpp.o"
Archiving built core (caching) in: C:\Temp\arduino_cache_917503\core\core_wemos_XI_xi_531ae38a65b2f7667865901469ffa0dd.a
Linking everything together...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-gcc" -Wall -Os -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Temp\arduino_build_424490/sketch_apr28a.ino.elf" "C:\Temp\arduino_build_424490\sketch\sketch_apr28a.ino.cpp.o" "C:\Temp\arduino_build_424490/core\core.a" "-LC:\Temp\arduino_build_424490" -lm
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Temp\arduino_build_424490/sketch_apr28a.ino.elf" "C:\Temp\arduino_build_424490/sketch_apr28a.ino.eep"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Temp\arduino_build_424490/sketch_apr28a.ino.elf" "C:\Temp\arduino_build_424490/sketch_apr28a.ino.hex"
Скетч использует 1078 байт (3%) памяти устройства. Всего доступно 29696 байт.
Глобальные переменные используют 9 байт динамической памяти.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Temp\arduino_build_424490/sketch_apr28a.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x62
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x62
avrdude done.  Thank you.
Проблема загрузки в плату. Помощь по загрузке: http://www.arduino.cc/en/Guide/Troubleshooting#upload .
   спасите, помогите !!!
Вы сообщения компилятора отключите, что бы простынь не печатало. А проблема в загрузчике. Мне кажется что atmega328 здесь не подходит.
Сообщения специально включил для полноты информации...
Не понял причем тут atmega328 ??? где я её использовал ???
LGT8F328D система комманд AVR, как у atmega328 только УВВ расширены. Скорее всего, что-то с переходником загрузчика. А куча предупреждений компилятора так это на совести разработчиков ПО платы.
renoshnik пише:Не понял причем тут atmega328 ??? где я её использовал ???
Блин, засада .... и как запустить эту балалайку ?!?!?!
Подключите USB-UART как у Ардуино, с ресетом. Проверьте правильность подключения RX/TX, может быть наоборот. И попробуйте еще раз. Экстремально, можно перепрошить загрузчик. Это atmega такая, немного улучшенная китайцами.
renoshnik пише:Блин, засада .... и как запустить эту балалайку ?!?!?!
USB-UART - менял и с ресетом и без...
RX/TX - проверял все правильно...
попробуйте еще раз - пробовал
можно перепрошить загрузчик - в принципе в пакете есть бутлоадеры  https://github.com/wemos/Arduino_XI/tre … s/lgt8fx8e
оставлю на крайний случай...
Думаю, может проблема в "винде" - у меня 64 ...
Эту проблему легко проверить теримналом, закоротив RX-TX. Могут быть непропаи в плате, я встречал такое.
renoshnik пише:Думаю, может проблема в "винде" - у меня 64 ...
на плате WEMOS замкнул RX-TX - все посылки нормально возвращается в терминале...
У же приближаюсь к радикальным мерам.... прошивке...
Чем его прошивать, что-то не нахожу в списках МК LGT8F328D ???
Вот это, точно, я сказать не могу. Нужно читать документацию. Возможно, что как atmega328, по SPI или SWD.
renoshnik пише:У же приближаюсь к радикальным мерам.... прошивке...
https://drive.google.com/file/d/0B8aj6Z … FhZG8/view
нашел вот такое, но для меня это сложно...  ![]()
Почитайте README в каталоге загрузчиков WEMOS XI, там должны быть инструкции.
Вы сначала попробуйте загрузить через нано, мини, про мини. Может какой нибудь и прокатит из загрузчиков. А нет - тогда советую зашить какой-нибудь посредством программатора.
Так для китайской LGT8F328D библиотеки же другие, специфичные. А отдельно библиоткеи и загрузчик не назначишь, без хакерства.
Green пише:Вы сначала попробуйте загрузить через нано, мини, про мини. Может какой нибудь и прокатит из загрузчиков. А нет - тогда советую зашить какой-нибудь посредством программатора.
Вот нашел видео https://kinotube.info/watch/kIpZhfFiUD8
только не могу найти как установить эту Larduino core w/LGT8F328D что-то нигде нет этой доски...
renoshnik пише:только не могу найти как установить эту Larduino core w/LGT8F328D что-то нигде нет этой доски...
Это первое, что сделал... НО !!! там появляется только одна "доска"  WEMOS XI а вот
такой "доски" - Larduino core w/LGT8F328D  там нет...
Какие ещё библиотеки! Человеку нужно загрузчик подобрать.)
А его, кроме как методом тыка, никак не подберешь.(
Остання редакція Green (2018-04-28 19:04:02)
... А его, кроме как методом тыка, никак не подберешь.(
Начать тыкать можно сюда: https://github.com/wemos/Arduino_XI/tre … s/lgt8fx8e
Green пише:... А его, кроме как методом тыка, никак не подберешь.(
Так отсюда я и начинал  https://github.com/wemos/Arduino_XI
установил как написано, появилась "доска" XI а дальше все в первом сообщении...  ![]()
или нужно было нажать пункт "Записать Загрузчик" ???
Остання редакція renoshnik (2018-04-28 19:44:37)
Если USB-UART работает и все соединено правильно то или не работает загрузчик или обрыв/кз в цепи питания или UART-a или битый чип. Запись загрузчика нужно делать программатором, обычно подключаемым к SPI. Просто нажать кнопку недостаточно. Eще, касательно WEMOS XI. Может не совпадать тип загрузчика, зависящий от наличия кварца в плате.
   не помогло....
тут даже при компиляции "пустого скетча" получаю ошибку
Arduino: 1.9.0-beta (Windows 7), Плата:"Larduino-Core w/ LGT8F88A"
Warning: Board LGT:LGT8F:lardu_88a doesn't define a 'build.board' preference. Auto-set to: LGT8F_LARDU_88A
Внимание: platform.txt из ядра 'Arduino AVR Boards' содержит устаревшие tools.avrdude.cmd.path={runtime.ide.path}/hardware/tools/avr/bin/avrdude, автоматически преобразовано в tools.avrdude.cmd.path={path}/bin/avrdude. Ожидайте обновления ядра.
Внимание: platform.txt из ядра 'Arduino AVR Boards' содержит устаревшие tools.avrdude.config.path={runtime.ide.path}/hardware/tools/avr/etc/avrdude.conf, автоматически преобразовано в tools.avrdude.config.path={path}/etc/avrdude.conf. Ожидайте обновления ядра.
Внимание: platform.txt из ядра 'Arduino AVR Boards' содержит устаревшие recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{build.path}/{archive_file}" "{object_file}", автоматически преобразовано в recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{archive_file_path}" "{object_file}". Ожидайте обновления ядра.
Внимание: platform.txt из ядра 'Arduino AVR Boards' содержит устаревшие recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {compiler.c.elf.flags} -mmcu={build.mcu} -o "{build.path}/{build.project_name}.elf" {object_files} "{build.path}/{archive_file}" "-L{build.path}" -lm, автоматически преобразовано в recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {compiler.c.elf.flags} -mmcu={build.mcu} -o "{build.path}/{build.project_name}.elf" {object_files} "{archive_file_path}" "-L{build.path}" -lm. Ожидайте обновления ядра.
exec: "avr-g++": executable file not found in %PATH%
Ошибка компиляции для платы Larduino-Core w/ LGT8F88A.
Этот отчёт будет иметь больше информации с
включенной опцией Файл -> Настройки ->
"Показать подробный вывод во время компиляции"и МК по ссылке немного не тот ... (88)
... тут даже при компиляции "пустого скетча" получаю ошибку
... и МК по ссылке немного не тот ... (88)
Да я знаю, по этим LGT8Fxxx нет никакой информации. И это за счастье. Работайте с пакетом для WEMOS XI и изучайте (88), что-то другое наврядли найдестся. А микроконтроллер сооблазнительный, еще и защита от ESD улучшена.
