#1 2021-07-25 13:28:53
olegxter
Зареєстрований: 2021-07-25
Допомога в програмуванні
Доброго дня, шановна спільнота.
Прошу допомоги в написанні програмок ...
Сам я щойно сів писати малу прогу для керуванням реле. не можу зрозуміти де помилка..
  Modul 2 relay + MAX6675 Switch control themperature
  Written by OT 24/07/2021
  --- thermocuple connection VCC -5V; GRD -GRD; pin SO -4; pin CS -5; pin SCK -6;
  --- RELAY connection - pin -22,23;
  --- timer (millis)
#include "max6675.h"
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
#define PIN_R1 22                  // pin that controls the RELAY 1
#define PIN_R2 23                  // pin that controls the RELAY 2
unsigned long currentTime;         // variable for timer MAX chip to stabilise
unsigned long currentTime2;        // variable for timer Relay1
unsigned long currentTime3;        // variable for timer Relay2
bool RELAYState=0;                 // variable relay 1
bool RELAYState2=0;                // variable relay 2
void setup()
  Serial.begin(9600);
  pinMode(PIN_R1, OUTPUT);          // declare pin 22 as output:
  pinMode(PIN_R2, OUTPUT);          // declare pin 23 as output:
 Serial.println("Temperature");      // display of temperature measurement, wait for MAX chip to stabilize
  if (millis() - currentTime > 5000)
    currentTime = millis();
                                       // basic test, print the current temp
  Serial.print("C = ");
  Serial.println(thermocouple.readCelsius());
  if(millis() - currentTime2 > 5000)   //  Checking the time for the relay 1
    currentTime2 = millis();           //  Change the state of the relay1 to the opposite
	  RELAYState=!RELAYState
	  digitalWrite(PIN_R1, RELAYState);
  if(millis() - currentTime3 > 8000)   //  Checking the time for the relay 2
    currentTime3 = millis();           //  Change the state of the relay2 to the opposite
	  RELAYState2=!RELAYState2
	  digitalWrite(PIN_R2, RELAYState2);
	                                   // if temprature goes above 480.0C, turn the relay OFF
  if (thermocouple.readCelsius() < 480.00)
      digitalWrite(PIN_R1, HIGH);          // turn the Relay1 Switch ON
	    digitalWrite(PIN_R2, HIGH);          // turn the Relay2 Switch ON
  } else {
      digitalWrite(PIN_R1, LOW);           // turn the Relay1 Switch OFF
      digitalWrite(PIN_R2, LOW);           // turn the Relay2 Switch OFF
повідомлення про помилку-
E:ArduinoModul___TC_R millisModul___TempControlModul___TempControl.ino: In function 'void loop()':
Modul___TempControl:52:4: error: expected ';' before 'digitalWrite'
Modul___TempControl:60:4: error: expected ';' before 'digitalWrite'
exit status 1
Дякую
#2 2021-07-25 15:26:25
olegxter
Re: Допомога в програмуванні
Підправив. lol
Дякую всім
Остання редакція olegxter (2021-07-25 15:26:57)
