#1 2020-06-28 21:18:40
Sergiy
Китайская Nano на ATmega 328pb
Не хочет работать совсем
сделал, как велит интернет в лице поважных: https://github.com/0x6470/ATmega328PB-Arduino-Nano-Clone-with-Bootloader
но в ответ получил такое:
Arduino: 1.8.12 (Windows 10), Плата:"ATmega328PB"
C:\Users\ADMIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude.exe -CC:\Users\ADMIN\AppData\Local\Arduino15\packages\ATmega328PB-incl-Bootloader\hardware\avr\0.1.0/tools/avrdude.conf -v -patmega328pb -cstk500v1 -PCOM3 -PCOM3 -b19200 -e -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xE2:m
avrdude.exe: Version 6.3-20190619
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Users\ADMIN\AppData\Local\Arduino15\packages\ATmega328PB-incl-Bootloader\hardware\avr\0.1.0/tools/avrdude.conf"
             Using Port                    : COM3
             Using Programmer              : stk500v1
             Overriding Baud Rate          : 19200
avrdude.exe: stk500_recv(): programmer is not responding
avrdude.exe: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
             AVR Part                      : ATmega328PB
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : STK500
             Description     : Atmel STK500 Version 1.x firmware
             Hardware Version: 2
             Firmware Version: 1.18
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | Ошибка при записи загрузчика.
################################################## | 100% 0.02s
avrdude.exe: Device signature = 0x00ff00
avrdude.exe: Expected signature for ATmega328PB is 1E 95 16
avrdude.exe done.  Thank you.
ЕСТЬ может кто, из понимающих? можете подсказать?
Дякую)))
Редактировался Sergiy (2020-06-28 21:25:06)
#2 2020-06-28 21:21:18
г0сть
Гость
Re: Китайская Nano на ATmega 328pb
ну дык карантин же. Вы ее на удаленку переведите
#3 2020-06-28 21:28:42
Sergiy
где то вычитывал, что конденсатор 1мкФ меж каких то ног спасает... ))))
но меж каких?
