Всім вітання. Одразу до проблеми. Є ось такий код:
#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
#include <string.h>
#include <TimeLib.h>
#include <WeeklyAlarm.h>
#include <SD.h>
#define DS1307_I2C_ADDRESS 0x68
#define SD_ChipSelectPin 10
RTC_DS1307 RTC;
char FileName[] = "00000000.DAT";
char FolderName[] = "logs/archived/";
char file[50];
char folder[50];
char location[1];
WeeklyAlarm weeklyAlarm;
Alarm alarm1;
void setup(){
RTC.begin();
if (! RTC.isrunning()) {
Serial.println(F("RTC is NOT running!"));
return;
Serial.begin(9600);
RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
setTime(8, 26, 0, 3, 2, 2020);
initial();
getFileName();
moveFiles();
weeklyAlarm.prettyPrintTime(now(), Serial);
alarm1.setCallback(callbackPlain);
alarm1.set(AlarmType::ALL_DAYS, ON, 8, 28);
weeklyAlarm.add(alarm1);
alarm1.printTo(Serial);
delay(2000);
weeklyAlarm.handler();
delay(5000);
void initial (){
File myFile;
if(!SD.begin(SD_ChipSelectPin))
Serial.println(F("Memory FAIL"));
return;
else{
Serial.println(F("Memory OK"));
delay(200);
//check directories
if (!SD.exists("logs/")) {
SD.mkdir("logs/");
if (!SD.exists("logs/archived/")) {
SD.mkdir("logs/archived/");
if (!SD.exists("logs/start")) {
myFile = SD.open("logs/start", FILE_WRITE);
myFile.close();
Serial.println(F("Dirs and files OK"));
void getFileName(){
DateTime now = RTC.now();
FileName[0] = (now.year()/1000)%10 + '0'; //To get 1st digit from year()
FileName[1] = (now.year()/100)%10 + '0'; //To get 2nd digit from year()
FileName[2] = (now.year()/10)%10 + '0'; //To get 3rd digit from year()
FileName[3] = now.year()%10 + '0'; //To get 4th digit from year()
FileName[4] = now.month()/10 + '0'; //To get 1st digit from month()
FileName[5] = now.month()%10 + '0'; //To get 2nd digit from month()
FileName[6] = now.day()/10 + '0'; //To get 1st digit from day()
FileName[7] = now.day()%10 + '0'; //To get 2nd digit from day()
//Serial.println(filename);
void moveFiles(){
File myFile;
File myFileIn;
File myFileOut;
strcpy(file,FileName);
strcpy(folder,FolderName);
strcat(location, folder);
strcat(location, file);
myFileIn = SD.open("logs/start", FILE_READ);
Serial.println(myFile.size());
if(myFileIn.size() > 2048){
Serial.println(F("File will be archived!!"));
myFileOut = SD.open(location, FILE_WRITE);
while (myFileIn.available()) {
myFileOut.write(myFileIn.read());
myFileIn.close();
myFileOut.close();
Serial.println(F("File archived!!"));
SD.remove("logs/start");
myFileIn = SD.open("logs/start", FILE_WRITE);
myFileIn.close();
else if(myFileIn.size() < 2048){
Serial.println(F("Log files OK"));
void callbackPlain() {
File myFile;
File myFileIn;
File myFileOut;
myFileIn.close();
myFileOut.close();
myFileIn.close();
}Це мій експеримент роботи "по крону". Суть проблеми
- при старті перевіряється чи наявні папки та файли, якщо ні - то вони створюються + якщо файл перевищує заданий розмір, то він копіюється до іншої папки...
initial();
getFileName();
moveFiles();
...перевіряв з різними розмірами файлів - працює, sd робоча.
Але, якщо я код перевірки та копіювання файлу "кидаю у крон", то система намертво підвисає, коли доходить до моменту виконная і це видно по монітору порта - результуючий напис не виводиться, а от якщо лишити просто вивід напису
Serial.println(F("Log files OK"));чи подібне - то все проходить. Чи хтось зтикався з подібним? Пробував використовувати різни ліби - результат однаковий. Грішу на ОЗУ, т.я. після компіляції лишається, приблизно 670б
Ну не тянет Нано такие ресурсоёмкие операции, а ОС Ардуино не имеет никаких проверок и защит от переполнения памяти. Расчитывать нужно почти каждый байт! ![]()
А что за платформаю.
Скорее всего Ваш Alarm создает новый процессорный таск таймер или ISR
Самое простое уйти от этого контекста и выполнять все в Loop
Например в контексте крона взведите флаг а в loop выполните
Ну если надо дождаться выпролнения можно либо критическую секцию либо другой флаг ![]()
