#1 2016-07-12 16:40:54
DJ_Wever
Зареєстрований: 2014-10-31
Arduino CW+GPS+SD
Это QRPp CW-маяк, работающий на 160/80/40-метровом диапазоне. Автор скетча Клименко Максим.
Есть желание доработать этот скетч для вставки GPS-координат в текст посылки и параллельного логирования координат и времени фиксации на SD-карту.
Что скажите господа?
// Arduino simply CW beacon
// (c) 2012 Max Klimenko
// emaster [at] mail.ru
// Beacon message
const char message[] = "VVV CQ CQ CQ DX DE BEACON BAND 40M 8000KHZ";
// Period of single point (ms)
const int point_time = 80;
// Carrier frequency divider.
// Carrier freq. (MHz) = 16 / (2 * (1 + freq_div))
const unsigned char freq_div = 1;
struct s_abc
        char letter;
        char sign[7];
const s_abc abc[] = {
        'A',".-", 'B',"-...", 'W',".--", 'G',"--.", 'D',"-..",
        'E',".", 'V',"...-", 'Z',"--..", 'I',"..",
        'J',".---", 'K',"-.-", 'L',".-..", 'M',"--", 'N',"-.",
        'O',"---", 'P',".--.", 'R',".-.", 'S',"...",
        'T',"-", 'U',"..-", 'F',"..-.", 'H',"....", 'C',"-.-.",
        'Q',"--.-", 'Y',"-.--", 'X',"-..-", '1',".----",
        '2',"..---", '3',"...--", '4',"....-", '5',".....",
        '6',"-....", '7',"--...", '8',"---..", '9',"----.",
        '0',"-----", '.',"......", ',',".-.-.-", ':',"---...",
unsigned char abc_size = sizeof(abc) / sizeof(abc[0]);
void setup()
  PORTB = 0;
  DDRB |= 1<<1;
  OCR1A = freq_div;
  TCCR1A = 0x48;
  TCCR1B = 0x09;
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
void send_letter(char l)
  if (l == ' ')
    delay(point_time * 7);
    return;
  unsigned char idx = 255;
  for (unsigned char i = 0; i < abc_size; i++)
    if (abc[i].letter == l)
      idx = i;
      break;
  if (idx == 255) return;
  const char *s = abc[idx].sign;
  for (unsigned char c = 0; s[c] != 0; c++)
    char q = s[c];
    DDRB |= 1<<1;
    if (q == '.') delay(point_time);
    else delay(point_time * 3);
    DDRB &= ~(1<<1);
    digitalWrite(13, LOW);   // set the LED off
    delay(point_time);
  delay(point_time * 2);
void loop()
  for (int n = 0; message[n] != 0; n++)
    send_letter(message[n]);
  delay(2000);
#2 2016-07-12 17:51:54
NoName
Customer
З Київ
Зареєстрований: 2014-07-08
Re: Arduino CW+GPS+SD
привет,
если на батарейке устройство,
и с магнитным креплением - то это незаконно )
#3 2016-07-12 18:02:17
DJ_Wever
Зато законно наблюдать за своим чадом, за домашним питомцем или автомобилем.
#4 2016-07-12 18:04:02
NoName
Customer
З Київ
в наше время даже необходимо  (
почему не GSM?
есть в целом адекватные решения, или академический интерес?
#5 2016-07-12 23:39:45
DJ_Wever
Тут интерес больше развлекательно-познавательный.
Есть масса готовых GPS/GSM-трекеров, есть Arduino-шилды с GPS/GSM/SD-слотом на борту, есть приемники и передатчики на 433 MHz,
но это все тленно перед голым Arduino и 10 сантиметровым куском провода с одной стороны и бытовым приемником с другой.
#6 2016-07-13 09:23:14
NoName
Customer
З Київ
DJ_Wever, если будете делать сами, помогу советом.
Ваш проект не сложный
вам прийдеться иметь дело  с   такими сообщениями
$GPRMC,125504.049,A,5542.2389,N,03741.6063,E,0.06,25.82,200906,,,*17
хеадер $,  футер *17
для начала  в
карточку пишете как есть (запись текстовой строки в файл примеров немеренно) все сообщения от модуля, мне нравится EB500, там было что то посвежее но уже не смотрел
вместо
char message[200] = "VVV CQ CQ CQ DX DE BEACON BAND 40M 8000KHZ";
копируете координаты в message, и дальше ловите их в эфире
а Вы первую часть уже сделали? работает?
сообщение "VVV CQ CQ CQ DX DE BEACON BAND 40M 8000KHZ"; словили? )
#7 2016-07-13 20:17:41
DJ_Wever
С реализацией проблем нет.
Словил, на бытовой приемник, на расстояние 2-х километров.
Остання редакція DJ_Wever (2016-07-13 22:34:58)
#8 2016-07-14 09:32:41
NoName
Customer
З Київ
DJ_Wever, что есть?
1. какой GPS
2. какой SD-shield
подскажу, и помогу, но делать будете сами.
проверяйте часть 2
http://arduino-diy.com/arduino-SD-karta
покажите фотку что получилось
Остання редакція NoName (2016-07-14 09:36:45)
#9 2016-07-15 09:46:00
Green
Зареєстрований: 2015-11-08
DJ_Wever пише:
А разве на бытовой приёмник получится "нормально" принять? Как я понимаю, нужен ещё CW гетеродин, не?
#10 2016-07-15 13:19:39
DJ_Wever
Как видите, принял.
А так ни что не мешать, поставить узкую "керамика" по второй ПЧ, или давить боковую полосу и слушать в SSB.
Для ленивых есть дегены.
#11 2016-07-15 15:42:46
Green
Я тоже вчера принял, но это не значит что все принимают. А если серьёзно, может нужно промодулировать выходной сигнал передачика нч сигналом? Вот тогда примут все.
#12 2016-07-15 19:34:29
DJ_Wever
А зачем его всем принимать? А если серьезно, вам не достаточно, что сигнал промодулирован CW-модуляцией?
Принцип вышеописанного маяка заключается в обычном генераторе прямоугольных (меандр) импульсов, от 16 битного таймера, до половины тактовой частоты, включаемый и выключаемый на определенный промежуток времени (точка-тире-пробел).
МК-ы в принципе нечего другого на своих ногах генерировать не могут, у них всего 2 состояния - высокий и низкий логический уровень. Это не ЦАП!
Стало быть и генерировать на голом МК мы ничего другого кроме меандра не сможем, а значит кроме CW нам не чего не светит.
Нет, есть конечно DDS-генераторы работающие на i2c, их можно использовать как самостоятельно, так и с помощью смесителя подмешивать НЧ, можно задействовав сразу несколько ног, выдавать по таблице ШИМ-импульс каждой ноги в определенный момент и с определенной скважностью, получиться синус, только очень низкой частоты.
Главный вопрос - ЗАЧЕМ?
Для передачи НЧ есть готовые трансиверы, для приема готовые приемники.
Мы эти маяком добились максимальной простоты, повторяемости, автономности и миниатюрности.
Например ATtiny13 в корпусе ssop8, размером меньше ногтя мизинца может генерировать CW с мощностью 20mW.
Без всяких доп.модулей, без обвязки, без отдельных передатчиков или генераторов - ВОТ В ЧЕМ ИЗЮМИНКА!
#13 2016-07-15 20:43:49
Green
Это всё понятно. Только Вы говорили о бытовом приёмнике... А на бытовом приёмнике CW (на слух) принимать неудобно/сложно, модуляции то нет, согласны? Но ничто не мешает промудулировать его на передающей стороне. На голом МК, без ничего! С тем что бы принимать на слух на бытовом приёмнике не изгаляясь. Именно ЗАТЕМ, я доходчиво объяснил?
#14 2016-07-15 20:48:27
Green
Точки и тире модулировать ещё 1-м кГц, к примеру. Ага?
#15 2016-07-15 21:11:51
DJ_Wever
Во-первых, на голом МК сделать это не получиться.
Во-вторых, повторюсь - все можно услышать на бытовой приемник, если вас не устраивает непромодулированный сигнал (пи-пи не 1кГц), паяйте на приемник свой гетеродин (навесным монтажом дело 5 минут). И пи-пи для вас будет любой частоты + сможете принимать радиолюбителей в SSB.
Принципы CW-модуляции надеюсь вам не надо разъяснять?
#16 2016-07-15 21:41:05
Green
DJ_Wever пише:
"Я ему про Фому, а он мне про Ерёму!"))
Почему не получится? CW модуляция получается, а ещё одна нет?)) Не вижу никаких проблем.
Удачи!
#17 2016-07-16 12:21:28
DJ_Wever
Да потому-что, я вам еще раз объясняю, то что МК генерирует меандр, это вообще нештатный режим контроллера, потому-что использования 16 битного таймера при постоянной составляющей одной инструкции дает 100 загрузку и лишь прерываниями мы исполняем смену этой-же самой инструкции на такую-же, только с другим периодом. Ни о какой НЧ модуляции и речи быть не может!
Мы здесь можем только изменить частоту генератора меандра, скважность и включить или выключить с разным периодом времени. И на этом ВСЕ!!!
Чувствую вы вообще не представляйте что такое CW-модуляция.
Настоящая морзянка ни-когда и не чем не модулировалась, это простая несушка.
Хотите на бытовом приемнике "пищалку" в 1кГц, ставьте в него соответствующий НЧ-генератор и подключайте к АМ-детектору.
Arduino не всесильна и вам не будет по щучьему велению модулировать АМ с НЧ сигналом в 1 кГц.
Остання редакція DJ_Wever (2016-07-16 12:25:38)
#18 2016-07-17 20:59:47
NoName
Customer
З Київ
уйдите лучше в демагогию как DJить для соседей в  FM, в дороге и на дому, 3-8 станции, ясен пень одновременно до 50 м
#19 2016-07-18 12:27:23
NoName
Customer
З Київ
и убедительная просьбе
давайте источники
страница Макса  Клименко
http://max-ter.livejournal.com/571.html
возможная схема
этот пост надыхнул Макса  на создание этой прошивки
http://www.radioscanner.ru/forum/topic32713.html
#20 2016-07-18 20:25:49
DJ_Wever
NoName, внимательней пожалуйста к моему первому посту - внимательней!
#21 2017-02-05 10:08:08
Green
DJ_Wever пише:
Вот только не надо, Ди-джей, меня учить CW-молуляции.)) Ибо имею МС именно по этой модуляции.)))
Ну вспомнил, и чо!)))))
