#1 2022-08-11 20:01:15
ВладQq
Зареєстрований: 2022-08-11
Помилка коомпіляції esp8266
Всім привіт
прошу допомоги з кодом esp
видає помилку при будь якому коді
ось помилка:
Arduino: 1.8.13 (Windows 10), Плата: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch,
In file included from C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/BlynkWidgets.h:14,
                 from C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/BlynkSimpleEsp8266.h:107,
                 from C:UsersВладікDesktopsketch_aug11asketch_aug11a.ino:1:
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/WidgetTimeInput.h: In constructor 'TimeInputParam::TimeInputParam(const BlynkParam&)':
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/WidgetTimeInput.h:45:43: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
   45 |             mStart = BlynkTime(it.asLong());
In file included from C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/WidgetTimeInput.h:15,
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkDateTime.h:65:5: note: because 'BlynkTime' has user-provided 'BlynkTime::BlynkTime(const BlynkTime&)'
   65 |     BlynkTime(const BlynkTime& t) : mTime(t.mTime) {}
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/WidgetTimeInput.h:59:42: warning: implicitly-declared 'constexpr BlynkTime& BlynkTime::operator=(const BlynkTime&)' is deprecated [-Wdeprecated-copy]
   59 |             mStop = BlynkTime(it.asLong());
In file included from C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkProtocol.h:19,
                 from C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/BlynkSimpleEsp8266.h:25,
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkUtility.h: At global scope:
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkUtility.h:96:6: warning: 'bool BlynkStrMatch(const char*, const char*)' defined but not used [-Wunused-function]
   96 | bool BlynkStrMatch(const char* pat, const char* txt) {
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkUtility.h:81:10: warning: 'uint32_t BlynkCRC32(const void*, size_t, uint32_t)' defined but not used [-Wunused-function]
   81 | uint32_t BlynkCRC32(const void* data, size_t length, uint32_t previousCrc32 = 0)
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkUtility.h:70:5: warning: 'int BlynkSQ2RSSI(int)' defined but not used [-Wunused-function]
   70 | int BlynkSQ2RSSI(int quality) {
C:Users\DocumentsArduinolibrariesblynk-library-mastersrc/Blynk/BlynkUtility.h:59:5: warning: 'int BlynkRSSI2SQ(int)' defined but not used [-Wunused-function]
   59 | int BlynkRSSI2SQ(int dBm) {
Traceback (most recent call last):
  File "C:Users\AppDataLocalArduino15packagesesp8266hardwareesp82663.0.2/tools/elf2bin.py", line 211, in <module>
    sys.exit(main())
  File "C:Users\AppDataLocalArduino15packagesesp8266hardwareesp82663.0.2/tools/elf2bin.py", line 183, in main
    out=args.out, eboot=args.eboot, app=args.app))
  File "D:objWindows-Release37win32_Releasemsi_pythonzip_win32cp866.py", line 19, in encode
UnicodeEncodeError: 'charmap' codec can't encode character 'u0456' in position 118: character maps to <undefined>
exit status 1
Помилка компіляції для плати NodeMCU 1.0 (ESP-12E Module).
наперед дякую!
#2 2022-08-12 16:22:04
Всаятко
Гість
Re: Помилка коомпіляції esp8266
А хде сам скэтч?
#3 2022-08-15 15:55:53
PolArt
Зареєстрований: 2021-11-28
Скетч часом не з архіву відкриваєте? Розархівуйте архів зі скетчами повністю і відкривайте готовий файл. Або запустіть нове вікно IDE і в нього копіПаст зробіть.
