#1 2017-06-10 12:35:54
goodspeedmen
З https://discord.gg/6hbs98y
Зареєстрований: 2016-10-02
Проблемы обработки кода
boolean compare, triger, inc_cw, nc_cww;
byte division,division_CW,division_CWW, backlash_CW, backlash_CWW, backlash;
int counter_lcd , calibre_lcd;
// настройка вннешнего прерывания INT0 и INT1.
//INT0 PD2. Mode: Falling Edge. INT1 PD2. Mode: Rising Edge.
EICRA = (1<<ISC11) | (1<<ISC10) | (1<<ISC01) | (0<<ISC00);
EIMSK = (1<<INT1) | (1<<INT0);
EIFR = (1<<INTF1) | (1<<INTF0);
PCICR = (0<<PCIE2) | (0<<PCIE1) | (0<<PCIE0);
if((digitalRead(10) == 0)&&(triger == 0)) //compare.
   temp++;
   if(temp == 0xff)
      if(counter_lcd < calibre_lcd) //motor_cww.
         compare = 0;
         PORTD |= (1<<5); //on motor cw.
         while(compare == 0)
         PORTD &= ~(1<<5); //off motor.
         PORTB |= (1<<4);  //on braking.
         braking = 0x3300; //13056 time braking.
         triger = 1;       //set triger.
         goto compare_end;
      if(counter_lcd > calibre_lcd) //motor_cww.
         compare = 0;
         PORTD |= (1<<4);//on motor cww.
         while(compare == 0)
         PORTD &= ~(1<<4); //off motor.
compare_end:
ISR(INT0_vect)//INT0 PD2. Mode: Falling Edge. обработка прерываний с деление и люфтом INT0 and INT1 - ON
cli();
if((inc_cw == 1)&&(digitalRead(3) == 0))// энкодер++.
 if(backlash_CW == backlash)//выбор люфта вперед.
   if(division_CW == division) //деление входных импульсов.
      counter_lcd++;
      if(compare == 0)
         if(counter_lcd == calibre_lcd)
            PORTD &= ~(1<<5);
            compare = 1;
      division_CW = 0;
      goto out_int_A;
   division_CW++;
   goto out_int_A;
   backlash_CW++;
   backlash_CWW = 0;
   division_CWW = 0;
   goto out_int_A;
if((inc_cww == 1)&&(digitalRead(3) == 1))//энкодер--.
   if(backlash_CWW == backlash)//выбор люфта назад.
      if(division_CWW == division)//деление входных импульсов.
         counter_lcd--;
         if(compare == 0)
                PORTD &= ~(1<<4);
                compare = 1;
         division_CWW = 0;
         goto out_int_A;
      division_CWW++;
      goto out_int_A;
  backlash_CWW++;
  backlash_CW = 0;
  division_CW = 0;
out_int_A:
inc_cw = 0;
inc_cww = 0;
sei();
//ISR(INT1_vect)//INT1 PD2. Mode: Rising Edge.
cli();
  if(digitalRead(2) == 0){inc_cw = 1; inc_cww = 0; goto out_int_B;}//энкодер++.
  if(digitalRead(2) == 1){inc_cww = 1; inc_cw = 0; goto out_int_B;}//энкодер--.
out_int_B:
sei();
Вот мой код обработке энкодера, смысл в том что есть переменная calibre_lcd к значению которой крутится двигатель. В первом прерывании задаются направление энкодера в нулевом отсчёт. В коде есть выборка люфта и деление входных импульсов от энкодера.
Проблема такова, не срабатывает вот этот код, двигатель крутится постоянно. Я убирал люфт и деление, проблема остаётся значит дело не в них?
if(compare == 0)
     { PORTD &= ~(1<<5);  // или PORTD &= ~(1<<4);
        compare = 1;
Когда я вынес код из прерывания все заработало нормально hmm
 while(compare == 0)
                  {PORTD &= ~(1<<5);  // или PORTD &= ~(1<<4);
                    compare = 1;
#2 2017-06-10 19:23:17
renoshnik
Зареєстрований: 2017-04-03
Re: Проблемы обработки кода
1 - уже достаточно написал тут про энкодер, читайте там все элементарно....
2 - что мешает сделать вывод в монитор для отладки программы ???
