Вместо #include "BasicStepperDriver.h" должно быть #include <BasicStepperDriver.h>
glory24 пише:BasicStepperDriver.ino:12:32: error: BasicStepperDriver.h: No such file or directory
Название файла .ino и файла .h не должны совпадать.
No such file or directory - переводчик в руки- нет файла или директории.
А дальше следсвие.
Переназвал файл .ino, теперь ругается так:
BasicStepperDriver8825.ino:12:32: error: BasicStepperDriver.h: No such file or directory
BasicStepperDriver8825:28: error: 'BasicStepperDriver' does not name a type
BasicStepperDriver8825.ino: In function 'void setup()':
BasicStepperDriver8825:39: error: 'stepper' was not declared in this scope
BasicStepperDriver8825.ino: In function 'void loop()':
картинка открывается правой кнопкой мышки
вот код
* Simple demo, should work with any driver board
* Connect STEP, DIR as indicated
* Copyright (C)2015 Laurentiu Badea
* This file may be redistributed under the terms of the MIT license.
* A copy of this license has been included with this distribution in the file LICENSE.
#include <Arduino.h>
// Motor steps per revolution. Most steppers are 200 steps or 1.8 degrees/step
#define MOTOR_STEPS 200
// All the wires needed for full functionality
#define DIR 9
#define STEP 8
//Uncomment line to use enable/disable functionality
//#define ENBL 7
// Since microstepping is set externally, make sure this matches the selected mode
// 1=full step, 2=half step etc.
#define MICROSTEPS 1
// 2-wire basic config, microstepping is hardwired on the driver
BasicStepperDriver stepper(MOTOR_STEPS, DIR, STEP);
//BasicStepperDriver stepper(MOTOR_STEPS, DIR, STEP, ENBL);
* Set target motor RPM.
* These motors can do up to about 200rpm.
* Too high will result in a high pitched whine and the motor does not move.
stepper.setRPM(5);// скорость вращения
// energize coils - the motor will hold position
// stepper.enable();
* Tell the driver the microstep level we selected.
* If mismatched, the motor will move at a different RPM than chosen.
stepper.setMicrostep(MICROSTEPS);
* Moving motor one full revolution using the degree notation
stepper.rotate(30);// Угол поворота
* Moving motor to original position using steps
//stepper.move(-200*MICROSTEPS);// Возврат на 200 шагов
// pause and allow the motor to be moved by hand
// stepper.disable();
delay(3000);
}BasicStepperDriver.ino:12:32: error: BasicStepperDriver.h: No such file or directory
А дальше следсвие.
BasicStepperDriver:28: error: 'BasicStepperDriver' does not name a type
BasicStepperDriver.ino: In function 'void setup()':
BasicStepperDriver:39: error: 'stepper' was not declared in this scope
BasicStepperDriver.ino: In function 'void loop()':
BasicStepperDriver:51: error: 'stepper' was not declared in this scope
Компилирую в Arduino 1.0.5
Скетч BasicStepperDriver из библиотеки StepperDriver
BasicStepperDriver.h как и положено лежит в папочке C:\Arduino\Arduino\libraries\StepperDriver\src
Ошибку выдает на эту строчку из скетча: BasicStepperDriver stepper(MOTOR_STEPS, DIR, STEP);
Этот же скетч в Arduino 1.6.12 проходит компиляцию без проблем
Как полечить Arduino 1.0.5 ?
