я не помню чем закончилась проверка,
кастомные мото - весчЪ
можно в теме продолжить, может есть желающие улучшить
* // file name harley_led.ino ( for SERJ )
* "THE BEER-WARE LICENSE" (Revision 00):
* <devgate.info эт gmail.com> wrote this file. As long as you retain this notice you
* can do whatever you want with this stuff. If we meet some day, and you think
* this stuff is worth it, you can buy me a beer in return.
* CHINGIZ THE FAIR SUN
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
* IN THE SOFTWARE.
* Date create: 2016.12.16
* Date change: 2017.01.13 10:51
* Date change: 2017.04.30 22:27 add level key detect
const int PIN_LED_left = 7;
const int PIN_LED_rigth = 8;
#define count_left_led_auto_off 322
#define count_rigth_led_auto_off 430
#define led_ON 0
#define led_OFF 1
typedef enum {
task_off_led_off = 0,
task_executed,
task_reset_off,
task_reset_on ,
task_off_led_on,
task_init,
} te_led_task_status;
typedef enum {
led_off = 0,
led_left_exe = 1,
led_rigth_exe = 2,
led_both_exe_1 = 3,
led_both_exe_2 = 4,
led_merry_christmas = 5,
} te_led_exe_status;
typedef struct
int pin_number;
int time_debounce;
unsigned long time_press ;
unsigned long time_release;
unsigned long time_last_press;
unsigned long time_last_release;
int press_level_detect;
bool status_press;
bool status_release;
bool interrupt_press;
bool interrupt_release;
bool need_release;
bool execute;
} tdpkey;
typedef struct
int pin_number;
int invert_pin_number;
int volume_off; // may be use PWM
int volume_on; // may be use PWM
unsigned long time_ON ;
unsigned long time_OFF;
int state;
unsigned long now_timer;
int step_exe;
unsigned long disabled_count_interrupt;
te_led_task_status status_led;
bool tobe_executed;
bool use_invert_pin;
} td_pled;
typedef enum {
TIMER_EXE = 0,
TIMER_DISABLED = 1,
TIMER_RUN = 2,
}TE_TIMER;
tdpkey key_left;
tdpkey key_rigth;
td_pled pled_left;
td_pled pled_rigth;
te_led_exe_status LED_STAT;
// #undef DEBUG
char debug_str[100];
TE_TIMER programm_count_down_uint32 ( unsigned long *timer , unsigned long shift )
if (*timer > 0 )
if (*timer > shift )
*timer -= shift;
return TIMER_RUN;
else
*timer = 0;
return TIMER_EXE;
return TIMER_DISABLED;
void hall_effect_interrupt ( void )
if ( TIMER_EXE == programm_count_down_uint32 (&pled_left.disabled_count_interrupt, 1 ) )
set_new_led_status ( led_off );
if ( TIMER_EXE == programm_count_down_uint32 (&pled_rigth.disabled_count_interrupt, 1 ) )
void setup()
key_left.time_debounce = 50;
key_rigth.time_debounce = 50;
pled_left.volume_off = 1;
pled_left.volume_on = 0;
pled_left.pin_number = 7;
pled_left.status_led = task_init;
pled_left.use_invert_pin = false;
pled_rigth.volume_off = 1;
pled_rigth.volume_on = 0;
pled_rigth.pin_number = 8;
pled_rigth.status_led = task_init;
pled_rigth.use_invert_pin = false;
pled_rigth.invert_pin_number = pled_left.pin_number;
pled_left.invert_pin_number = pled_rigth.pin_number;
key_left.pin_number = 2;
key_rigth.pin_number = 4;
pinMode(key_left.pin_number, INPUT);
pinMode(key_rigth.pin_number, INPUT);
Serial.begin(9600); // setup serial
led_task(&pled_left, 0);
led_task(&pled_rigth,0);
key_rigth.need_release = true;
key_left.need_release = true;
key_rigth.press_level_detect = LOW;
key_left.press_level_detect = LOW;
set_new_led_status (led_off);
attachInterrupt(0, hall_effect_interrupt, RISING);
void clear_fkey_interrupt ( tdpkey *pkey )
pkey->interrupt_release = false;
pkey->interrupt_press = false;
pkey->need_release = true;
void fKey (tdpkey *pkey, int time_elapsed )
if ( digitalRead( pkey->pin_number) == pkey->press_level_detect )
pkey->time_press += time_elapsed;
else
pkey->time_release += time_elapsed;
// кнопка была отжата
if ( pkey->time_release > pkey->time_debounce )
if ( pkey->status_release == false )
pkey->time_press = 0;
pkey->status_release = true;
pkey->status_press = false;
if ( pkey->need_release == false )
pkey->interrupt_release = true;
pkey->need_release = false;
pkey->time_last_release = pkey->time_release;
pkey->time_release = 0;
#ifdef DEBUG
sprintf ( debug_str,"key_release"); Serial.println ( debug_str );
#endif
if ( pkey->time_press > pkey->time_debounce )
if ( pkey->status_press == false )
pkey->status_press = true;
pkey->status_release = false;
pkey->interrupt_press = true;
#ifdef DEBUG
sprintf ( debug_str,"key_press"); Serial.println ( debug_str );
#endif
return;
void led_task ( td_pled *pled, int time_elapsed )
TE_TIMER status;
switch ( pled->status_led )
case task_executed:
pled->tobe_executed = true;
break;
case task_init:
pinMode(pled->pin_number, OUTPUT);
digitalWrite(pled->pin_number, pled->volume_off);
if ( pled->use_invert_pin )
digitalWrite ( pled->invert_pin_number, pled->volume_on);
pled->tobe_executed = false;
break;
case task_off_led_off:
break;
case task_reset_off:
pled->step_exe = 1;
digitalWrite ( pled->invert_pin_number, pled->volume_off);
pled->now_timer = pled->time_OFF;
time_elapsed = 0;
pled->status_led = task_executed;
break;
case task_reset_on:
pled->step_exe = 0;
digitalWrite(pled->pin_number, pled->volume_on);
pled->now_timer = pled->time_ON;
time_elapsed = 0;
break;
case task_off_led_on:
break;
if ( pled->tobe_executed )
status = programm_count_down_uint32 (&pled->now_timer, time_elapsed);
switch ( status )
case TIMER_EXE:
// case TIMER_DISABLED:
switch ( pled->step_exe )
// led on
case 0:
pled->step_exe = 1;
break;
default:
case 1:
digitalWrite( pled->pin_number, pled->volume_off);
pled->step_exe = 0;
break;
break;
void set_new_led_status ( te_led_exe_status new_status )
if ( new_status == LED_STAT ) return;
#ifdef DEBUG
sprintf ( debug_str,"set new state[%d]" , new_status );
#endif
switch ( new_status )
default:
case led_off:
pled_left.status_led = task_off_led_off;
pled_rigth.status_led = task_off_led_off;
pled_left.disabled_count_interrupt = 0;
pled_rigth.disabled_count_interrupt = 0;
break;
case led_left_exe:
pled_left.status_led = task_reset_on;
pled_left.time_ON = 200;
pled_left.time_OFF = 800;
pled_left.disabled_count_interrupt = count_left_led_auto_off;
break;
case led_rigth_exe:
pled_rigth.status_led = task_reset_on;
pled_rigth.time_ON = 200;
pled_rigth.time_OFF = 800;
pled_rigth.disabled_count_interrupt = count_rigth_led_auto_off;
break;
case led_both_exe_1:
pled_left.time_OFF = 1000;
pled_rigth.time_OFF = 1000;
break;
case led_both_exe_2:
pled_left.time_ON = 100;
pled_left.time_OFF = 500;
pled_rigth.time_ON = 100;
pled_rigth.time_OFF = 500;
break;
case led_merry_christmas:
// pled_left.status_led = task_reset_on;
// pled_left.time_ON = 200;
// pled_left.time_OFF = 400;
// pled_left.disabled_count_interrupt = 0;
pled_rigth.time_ON = 300;
pled_rigth.time_OFF = 150;
pled_rigth.use_invert_pin = true;
break;
pled_left.tobe_executed = true;
pled_rigth.tobe_executed = true;
LED_STAT = new_status;
static unsigned long sec;
static unsigned long old_time;
unsigned long new_time;
unsigned long _time;
new_time = millis();
_time = new_time - old_time;
old_time = new_time;
fKey (&key_left , _time );
fKey (&key_rigth, _time );
// to be executed both led
if ((key_left.interrupt_press )&&( key_rigth.status_press))
set_new_led_status ( led_both_exe_1 );
clear_fkey_interrupt (&key_rigth);
clear_fkey_interrupt (&key_left);
if ((key_rigth.interrupt_press )&&( key_left.status_press))
set_new_led_status ( led_both_exe_2 );
if ( key_left.interrupt_release )
key_left.execute = true;
if ( key_rigth.interrupt_release )
key_rigth.execute = true;
// BMW
if ( key_rigth.interrupt_press )
if ( key_rigth.time_press > 1200 )
if ( key_left.interrupt_press )
if ( key_left.time_press > 1200 )
set_new_led_status ( led_merry_christmas );
if ( key_left.execute )
key_left.execute = false;
switch ( LED_STAT )
case 0: set_new_led_status ( led_left_exe ); break;
default: set_new_led_status ( led_off ); break;
if ( key_rigth.execute )
key_rigth.execute = false;
switch ( LED_STAT )
case 0: set_new_led_status ( led_rigth_exe ); break;
if ( pled_left.tobe_executed == true )
led_task (&pled_left, _time);
if ( pled_rigth.tobe_executed == true )
led_task (&pled_rigth,_time);
switch ( programm_count_down_uint32 (&sec, _time) )
case TIMER_EXE:
sec = 5000;
#ifdef DEBUG
sprintf ( debug_str,"----" );
#endif
break;
}Скажите этот проект зделали и если зделали можно пожевится скетчем?
Моё мыло ded.izya.dnepr@gmail.com
Я так понимаю, что 3-й вывод на схеме будет задействован для датчика?
Датчик скорости взят с ваз 2110. Более подробно смогу сазать завтра попаду в гараж - запишу маркировку.
А теперь по поводу лавины, это лавина которая в Сумах?
контакты на почте
сегодня не факт, на разведку в кинотеатр Лавины поеду )
если в том же "дистрикте", присоединяйтесь )
набросок схемы
https://www.dropbox.com/s/ob0qr7s0sh3z3n0/test-chem.png?dl=0
а что за датчик скорости ? дайте datasheet
Ок. Буду рад пообщаться. В районе 21:00 завтра устроит.?
задача несложная, скайп скинул на почту, в Сб или Вс вечером можем довести рабочего состояния Вашу плату.
Вот как раз для экспериментов и брал здесь на сайте "кита". И все уже смонтировано на печатную плату. Вот только с программами пока тяжко. Учусь. Кое что уже есть но пока не работает.
привет, имеет смысл сделать, но не на Nano, в такие платы пихают отбраковку или вообще не делают температурные тесты на партию, это простенький коммерческий чип, вы то запустите, но есть шансы что за месяц будете новый девайс делать , но с другой стороны может и 30 лет отработать )
если не "горит" вот прямо за наделю сделать - отпишитесь
т.е. так - такую задачу может сделать любой с этого форума
но я рекомендую не использовать "киты".
add, можно сделать и на этой плату, после монтажа, залейте ее герметиком
PLAST 2000 для разъемов, 3M, Loctite неплохие
Датчик скорости будет выдавать сигналы 7 сигналов на 1 метр.
выключение светиков будет не корректным - противоречие в условии
Есть в наличии arduino nano v3. На цифровые выводы 2 и 4 подключены нефиксированные кнопки. На выводы 7 и 8 светодиоды, и на аналоговый вывод датчик скорости. Нужно чтобы при нажатии кнопки на пине 2 начинал мигать светодиод 7, а при нажатии кнопки 4-восьмой. Выключение должно происходить от нажатия любой из кнопок и от датчика скорости после100метров. При одновременном нажатии двух кнопок оба канала должны мигать синхронно.
