Параметри
Назад
Євгеній
2022-09-28 00:08:23
Тема закрита бо завантажив код , не пришлося випвювати чіп , він живий)
Результат підключення і розьяснення в pdf файлі в низу .
https://drive.google.com/file/d/1RftXt2 … sp=sharing
Євгеній
2022-09-27 16:53:08
esptool.py v3.0-dev
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: приховав)
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4227.9 kbit/s)...
Hash of data verified.
Compressed 17120 bytes to 11164...
Writing at 0x00001000... (100 %)
Wrote 17120 bytes (11164 compressed) at 0x00001000 in 1.0 seconds (effective 136.0 kbit/s)...
Compressed 692432 bytes to 395728...
Writing at 0x00010000... (4 %)
Writing at 0x00014000... (8 %)
Writing at 0x00018000... (12 %)
Writing at 0x0001c000... (16 %)
Writing at 0x00020000... (20 %)
Writing at 0x00024000... (24 %)
Writing at 0x00028000... (28 %)
Writing at 0x0002c000... (32 %)
Writing at 0x00030000... (36 %)
Writing at 0x00034000... (40 %)
Writing at 0x00038000... (44 %)
Writing at 0x0003c000... (48 %)
Writing at 0x00040000... (52 %)
Writing at 0x00044000... (56 %)
Writing at 0x00048000... (60 %)
Writing at 0x0004c000... (64 %)
Writing at 0x00050000... (68 %)
Writing at 0x00054000... (72 %)
Writing at 0x00058000... (76 %)
Writing at 0x0005c000... (80 %)
Writing at 0x00060000... (84 %)
Writing at 0x00064000... (88 %)
Writing at 0x00068000... (92 %)
Writing at 0x0006c000... (96 %)
Writing at 0x00070000... (100 %)
Wrote 692432 bytes (395728 compressed) at 0x00010000 in 35.1 seconds (effective 157.6 kbit/s)...
Compressed 3072 bytes to 128...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 774.8 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Євгеній
2022-09-27 16:45:52
Я знайшов вирішення проблеми , дещо були в мене інші резистори а це так як вважаю правельніше ,робоча схема :
https://drive.google.com/file/d/1EU_C4M … sp=sharing
г0cть
2022-09-26 19:25:19
Євгеній пише:
здається інженери вже за нас все зробили і намалювали як воно довжно бутми ,
Вот именно. Делаете в точности как на схеме и не парите мозг
Євгеній
2022-09-26 15:41:48
да я хотів думку узнати що ви скажете після світлодіода , так я хочу автомат ,
лиш одне в мене транзістори інші ,  h21 високий ,так наприклад ток на контакті EN рівний 3.3/ 12K = 0,000275 A
а щоб керувати таким током по тому шаблону що я вирішував раніш потрібно на базу резістор з номіналом 2.9МОм
а після таких цифер в мене виникає питання чи правильно порахував і ще чи воно буде
після цього працювати якщо я навіть і знайду цей номінал ?
г0cть
2022-09-26 15:05:18
Євгеній пише:
на колектор який приходить ток повинен мабуть бути ну нехай 0.02А , ток світіння світлодіода) образно
При чем тут ток какого-то светодиода? Если вам лень нажимать кнопки для перевода модуля в режим загрузки и решили сделать автомат, то вам всего лишь нужно по сигналам DTR RTS обеспечить соответствующие уровни логического 0 и 1 на пинах esp
Євгеній
2022-09-26 14:38:39
@г0cть добрий день.
модуль E32(E433Т30S) не розпаяний.
https://drive.google.com/file/d/1MY1bo5 … sp=sharing
Обновив схему підключення з "програматором" , є транзістори але неті що потрібні ,використав свої ,
номінали резисторів на базу поставив по 41К  , а на U1 и U2 по 10К , ось їх думаю треба буде замінить
бо розрахунок ключів мабуть не правильний , треба передивись відеоматеріал  ,хоча як я розумі то треба зробить так
в нас 3.3 в напруги значить резістор має бути  165 Ом . Керуючий резістор на базі залежить від h21 =Ik/Ib ,в мене 326 .
0.02А /326 =  0,00006135 A  ток керуючий базою .R =U/R. 2.5v/ 0,00006135 A =40750 Ом .
Питання для розваги скільки буде  0.005 * 2 )
г0cть
2022-09-26 01:02:22
Євгеній пише:
я все виконав як книжка пише .
Не знаю что там ваша  книжка пишет, не читал. Но вы ее похоже тоже читали невнимательно. Про схему и последовательность действий я не зря спрашивал. В общем, если я правильно понял, ESP32 запаяна на вашу плату, схема которой приведена выше? Для прошивки вам нужно после подачи питания нажать кнопки (на вашей схеме) SW1 и SW2. Отпустить сначала SW2, потом SW1. После этого запустить процесс загрузки. Еще момент - резисторы, которые  на вашей схеме почему-то обозначены U1 и U2, номиналом 180 кОм? ИМХО многовато, обычно не больше 10кОм. Дальше, модуль E32(E433Т30S) тоже запаян? Если да, то он может мешать процессу загрузки
Євгеній
2022-09-26 00:31:30
Плата незовсім вдала для програмування ,на етапі праграмування розпаяне  тільки головне  ,щоб залити код .
По залізу блок харчування на 5в 2А підключаю до перетворбвача що на платі , через проводки ,
від цього мене горить світлодіод , горить діод і на перетворювачі на 3.3 в .До плати припаяно  USB - UART TTL FT232RL конвертер , такі контакти GND,DTR,RTS,TXD,RXD . Вставляю  USB - UART TTL FT232RL конвертер в ноутбук .По коду я пройшов всі загрузки і ініціалізації
згідно навчального матеріалу - легкий старт . Лінк на сайт я оставляв там можна почитать  ,я все виконав як книжка пише .
Получаеться що чіп непрацює а інший модуль завантажився . В косолі вставляку такий участок  коду нижче привів  і жму  enter .
/home/evgen/.espressif/python_env/idf4.4_py3.8_env/bin/python ../esp-idf/components/esptool_py/esptool/esptool.py -p /dev/ttyUSB0 -b 460800 --before default_reset --after hard_reset --chip esp32  write_flash --flash_mode dio --flash_size detect --flash_freq 40m 0x1000 build/bootloader/bootloader.bin 0x8000 build/partition_table/partition-table.bin 0x10000 build/hello_world.bin
esptool.py v3.3.2-dev
г0cть
2022-09-25 23:45:16
#17 - номер сообщения. Чтобы вам не пришлось общаться с космосом лишний раз повторюсь - огласите последовательность ваших действий при прошивке
Євгеній
2022-09-25 23:42:01
17# Це число ,  я в загадки не іграю , з космосом через стени не общаюсь , якщо так відповідати то
надовго мене точно не хватить) незнаю як вас , хоча ви любітель всім відповісти ))
г0cть
2022-09-25 23:34:03
Схему пока оставим, есть вопросы по ней, но пока ответьте на #17
Євгеній
2022-09-25 23:26:19
@г0cть . Приклад ,я незовсім зрозумів ,потрібна схема ,я вже приводив схему та яка в документах значиться
як це не з інтернету ? https://drive.google.com/file/d/1kcudg4 … sp=sharing
І ще всетаки є відміності ,там правда модуль чуть по иншову виглядає
https://drive.google.com/file/d/1zwE91Z … sp=sharing
г0cть
2022-09-25 23:21:31
А теперь еще огласите весь список пжлста smile последовательность ваших действий при прошивке
г0cть
2022-09-25 23:05:35
Я взагалі мав на увазі схему підключення для прошивки, ну ОК, маємо те що маємо ... smile
