...Вже декілька тижнів по вечорам сижу і ніяк не розберусь з антеною. ...
Можливо, допоможе ця інструкція - https://habr.com/ru/post/476716/. Тут йдеться про з'єднання по ефіру двох радіо модулів nRF24L01+ без антен і з антенами.
максимум чого вдалось добитись це цим скетчом.
/* Crazy People
* By Mike Cook April 2009
* Three RFID readers outputing 26 bit Wiegand code to pins:-
* Reader A (Head) Pins 2 & 3
* Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
* Then a sting is sent to processing
volatile long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
reader1Count++;
reader1 = reader1 << 1;
reader1 |= 1;
void reader1Zero(void) {
reader1Count++;
void setup()
Serial.begin(9600);
// Attach pin change interrupt service routines from the Wiegand RFID readers
attachInterrupt(0, reader1Zero, RISING);//DATA0 to pin 2
attachInterrupt(1, reader1One, RISING); //DATA1 to pin 3
delay(10);
// the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
// so this gives a pulse to each reader input line to get the interrupts working properly.
// Then clear out the reader variables.
// The readers are open collector sitting normally at a one so this is OK
for(int i = 2; i<4; i++){
pinMode(i, OUTPUT);
digitalWrite(i, HIGH); // enable internal pull up causing a one
digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
pinMode(i, INPUT);
delay(10);
// put the reader input variables to zero
reader1 = 0;
reader1Count = 0;
//digitalWrite(13, HIGH); // show Arduino has finished initilisation
if(reader1Count >=26){
//Serial.print(" Reader 1 ");
//Serial.println(reader1,HEX);
// Serial.println("A");
//Serial.println(reader1& 0xfffffff);
int serialNumber=(reader1 >> 1) & 0x3fff;
int siteCode= (reader1 >> 17) & 0x3ff;
Serial.print(siteCode);
Serial.print(" ");
Serial.println(serialNumber);
reader1 = 0;
reader1Count = 0;
digitalWrite(13,HIGH);
delay(2000);
digitalWrite(13,LOW);
але отримую відповідь
477 1475
477 1475
989 1475
989 1475
477 1475
477 1475
один і той самий ключ.
видає такі цифри.
хоча фактично код ключа
56 5A 11 40 BE
Прошу допомогти знатоків.
є антенна дальнбого зчитуванння
https://www.aliexpress.com/i/32656012971.html?ws_ab_test=searchweb0_0%2Csearchweb201602_0%2Csearchweb201603_0%2CppcSwitch_0&algo_pvid=abd73e95-ded7-4829-b6c2-4e79628de83b&aff_platform=portals-tool&sk=_Ao9adF&aff_trace_key=789d6c3fcf9c4205bf664ab0469fb1e2-1610999051736-09580-_Ao9adF&terminal_id=e7b9506ff36b4ad0add310c071420c60&algo_expid=abd73e95-ded7-4829-b6c2-4e79628de83b-27
неможу ніяк подружити її з ардуіно(
антена реагує, пікаї, діод моргає, данні на ардуіно передає. але якусь абракадабру
є браслети з рфід 125 кгц. потрібно порівнювати в базі і дозволяти або ні доступ.
але то вже геть інша історія.
допоможіть будь ласка подружити його з ардуіно. щоб можна було бачити в моніторі порта код ключа.
