Параметри
Назад
г0сть
2019-05-20 19:38:25
ну и че у вас все переключатели под одним номером?
switch_1 и PIN_SWITCH_1
VLADQW
2019-05-20 18:04:26
   -- New project --
   This source code of graphical user interface
   has been generated automatically by RemoteXY editor.
   To compile this code using RemoteXY library 2.3.5 or later version
   download by link http://remotexy.com/en/library/
   To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
     - for ANDROID 4.3.1 or later version;
     - for iOS 1.3.5 or later version;
   This source code is free software; you can redistribute it and/or
   modify it under the terms of the GNU Lesser General Public
   License as published by the Free Software Foundation; either
   version 2.1 of the License, or (at your option) any later version.
//        RemoteXY include library          //
// определение режима соединения и подключение библиотеки RemoteXY
#define REMOTEXY_MODE__ESP8266WIFI_LIB_POINT
#include <ESP8266WiFi.h>
#include <RemoteXY.h>
// настройки соединения
#define REMOTEXY_WIFI_SSID "RemoteXY"
#define REMOTEXY_WIFI_PASSWORD "12345678"
#define REMOTEXY_SERVER_PORT 6377
// конфигурация интерфейса
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
  { 255,4,0,0,0,71,0,8,13,1,
  2,1,14,3,35,15,2,26,31,31,
  79,78,0,79,70,70,0,2,1,14,
  26,35,15,2,26,31,31,79,78,0,
  79,70,70,0,2,1,14,49,35,15,
  2,26,31,31,79,78,0,79,70,70,
  0,2,1,14,72,35,15,2,26,31,
  31,79,78,0,79,70,70,0 };
// структура определяет все переменные вашего интерфейса управления
struct {
    // input variable
  uint8_t switch_1; // =1 если переключатель включен и =0 если отключен
    // other variable
  uint8_t connect_flag;  // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
//           END RemoteXY include          //
#define PIN_SWITCH_1 D1
#define PIN_SWITCH_1 D2
#define PIN_SWITCH_1 D3
#define PIN_SWITCH_1 D4
void setup()
  RemoteXY_Init ();
  pinMode (PIN_SWITCH_1, OUTPUT);
  // TODO you setup code
void loop()
  RemoteXY_Handler ();
  digitalWrite(PIN_SWITCH_1, (RemoteXY.switch_1==0)?LOW:HIGH);
  // TODO you loop code
  // используйте структуру RemoteXY для передачи данных
