код осветляет забор всего на 9 минут (
с 23:31 - 23:40 'маловато (
Робочий код кому потрібно.
Управліня реле по часу
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
// Convert normal decimal numbers to binary coded decimal
int Relay = 4;
byte decToBcd(byte val)
return( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return( (val/16*10) + (val%16) );
void setup()
Wire.begin();
Serial.begin(9600);
pinMode(Relay, OUTPUT);
digitalWrite(Relay, HIGH);
// set the initial time here:
// DS3231 seconds, minutes, hours, day, date, month, year
//setDS3231time(30,00,1,2,22,03,16);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(decToBcd(second)); // set seconds
Wire.write(decToBcd(minute)); // set minutes
Wire.write(decToBcd(hour)); // set hours
Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
Wire.write(decToBcd(month)); // set month
Wire.write(decToBcd(year)); // set year (0 to 99)
Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0); // set DS3231 register pointer to 00h
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void displayTime()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
// send it to the serial monitor
Serial.print(hour, DEC);
// convert the byte variable to a decimal number when displayed
Serial.print(":");
if (minute<10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second<10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day of week: ");
switch(dayOfWeek){
case 1:
Serial.println("Sunday");
break;
case 2:
Serial.println("Monday");
break;
case 3:
Serial.println("Tuesday");
break;
case 4:
Serial.println("Wednesday");
break;
case 5:
Serial.println("Thursday");
break;
case 6:
Serial.println("Friday");
break;
case 7:
Serial.println("Saturday");
break;
void loop()
&year);
if(hour == 23 && minute == 31) {digitalWrite(Relay, LOW);
}if(hour == 23 && minute == 40) {
displayTime();
поставити вкл 20:00 викл 24:00 кожен день
А почему-бы не взять и не купить готовое суточное реле?
http://www.energoshop.in.ua/Rele-vremen … rezhim.htm
а как планируете выставлять время вкл и время выкл
є Arduino Nano ATmega328 і годинник на dsc3231
потрібно включати,виключати реле в певний час
потрібен скетч
"Осветления забора по часам" это пять с + )
дохтур, "еще нужно вкл откл водонапорной башти от тиску води"
задвижка баттерфляй
дохтур, у меня шо то болит, вылечити ?
легко!
так и вы - неужели трудно чётко и ясно сформулировать задачу ?
или вы думаете по вашим формулировкам вам кто то поможет ![]()
да осветления забора. Нужно чтоби вкл в 8 часов и викл в 12
Осветление забора? Нет проблем.
вы бы более полно описали задание
нужно включать і виключать осветления от таймера
