#1 2018-03-19 22:41:43
angruh
Зареєстрований: 2018-02-17
ограничения на ввод в lcd
Нужно при введении num1 и num2  ограничивать количество символов до 6 но как это сделать
#include <Keypad.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(14,15,16,17,18,19);
long num1,num2 ;
double total;
char operation,button;
int n=1;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','+'},
  {'4','5','6','-'},
  {'7','8','9','*'},
  {'C','0','=','/'}
byte rowPins[ROWS] = {9,8,7,6};
byte colPins[COLS] = {5,4,3,2};
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup()
  lcd.begin(16,2);
  Serial.begin(9600);
void loop()
  while(1)
    button = customKeypad.getKey();
    if (button=='C')
      num1=0;
      num2=0;
      total=0;
      operation=0;
      lcd.clear();
    if (button >='0' && button <='9')
      num1 = num1*10 + (button -'0');
      lcd.setCursor(0,0);
      lcd.print(num1);
	if (num1 !=0 && (button=='-' || button=='+' || button=='*' || button=='/'))
      operation = button;
      lcd.setCursor(7,0);
	  while ((num1/=10) > 0) n++;
	  Serial.println(n);
      if(n >7)
        num1=0;
        num2=0;
        total=0;
        operation=0;
        lcd.clear();
        lcd.print("Error");
        break;
      n=0;
      lcd.print(operation);
      break;
  while(1)
    if (button =='C')
      break;
    if (button=='C')
      num1=0;
      num2=0;
      total=0;
      operation=0;
      lcd.clear();
      break;
      num2 = num2*10 + (button -'0');
      int n=1;
	  Serial.println(n);
      if(n >6)
        num1=0;
        num2=0;
        total=0;
        operation=0;
        lcd.clear();
        lcd.print("Error");
        break;
      lcd.setCursor(8,0);
      lcd.print(num2);
    if (button == '=' && num2 !=0)
      domath();
      break;
  while(1)
    if (button =='C')
      break;
    if (button =='C')
      lcd.clear();
      lcd.setCursor(0,0);
      num1=0;
      num2=0;
      total=0;
      operation=0;
      break;
void domath()
  switch(operation)
    case '+':
      total = num1+num2;
      break;
    case '-':
      total = num1-num2;
      break;
    case '/':
      if(num2 == 0)
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("ERROR");
      total = (float)num1/(float)num2;
      break;
    case '*':
      total = num1*num2;
      break;
  lcd.setCursor(0,1);
  lcd.print('=');
  lcd.setCursor(1,1);
  lcd.print(total);
#2 2018-03-20 00:59:02
vvr
Зареєстрований: 2015-04-12
Re: ограничения на ввод в lcd
завести счётчик нажатий.
