Параметри
Назад
0z0n
2020-12-24 14:50:06
Получилось. Пасиб!
0z0n
2020-12-24 14:33:59
Honey пише:
Wire.requestFrom(8, 16);
Пасиб огромное
А вот здесь на 16 менять не надо в операции сравнения?
   myInts1 = Wire.read ();
   myInts1 <<= 8; /// 16 здесь не надо?
   myInts1 |= Wire.read ();
Honey
2020-12-24 14:26:57
0z0n
2020-12-24 14:06:07
Помогите плиз взят пример:
Мастер прием:
#include <Wire.h>
int result1 = 2;
int result2 = 2;
int result3 = 2;
int result4 = 2;
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.requestFrom(8, 8);    // request 6 bytes from slave device #8
  while (Wire.available()) { // slave may send less than requested
   result1 = Wire.read ();
   result1 <<= 8;
   result1 |= Wire.read ();
   result2 = Wire.read ();
   result2 <<= 8;
   result2 |= Wire.read ();
   result3 = Wire.read ();
   result3 <<= 8;
   result3 |= Wire.read ();
   result4 = Wire.read ();
   result4 <<= 8;
   result4 |= Wire.read ();
      Serial.print(result1);Serial.print("  ");Serial.print(result2);Serial.print("  ");Serial.print(result3);Serial.print("  ");Serial.println(result4);
  delay(500);
Слейв отдача:
#include <Wire.h>
    int value1 = -12350;  // ie. 0x04 0xD2
    int value2 = -1350;
    int value3 = 2350;
    int value4 = 12350;
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onRequest(requestEvent); // register event
  delay(100);
  value1 = value1 + 1 ;
  value2 = value2 + 1 ;
  value3 = value3 + 1 ;
  value4 = value4 + 1 ;
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent() {
  Wire.write (highByte (value1));
  Wire.write (lowByte (value1));
  Wire.write (highByte (value2));
  Wire.write (lowByte (value2));
  Wire.write (highByte (value3));
  Wire.write (lowByte (value3));
  Wire.write (highByte (value4));
  Wire.write (lowByte (value4));
  // as expected by master
Переделал отдачу
for (int i = 0; i < 8; i++) {
  Wire.write (highByte (myInts[i]));
  Wire.write (lowByte (myInts[i]));
Прием:
void WareReadSlave() {  // request 8 bytes from slave device #8
   myInts1 <<= 8;
   myInts2 = Wire.read ();
   myInts2 <<= 8;
   myInts2 |= Wire.read ();
   myInts3 = Wire.read ();
   myInts3 <<= 8;
   myInts3 |= Wire.read ();
   myInts4 = Wire.read ();
   myInts4 <<= 8;
   myInts4 |= Wire.read ();
   myInts5 = Wire.read ();
   myInts5 <<= 8;
   myInts5 |= Wire.read ();
   myInts6 = Wire.read ();
   myInts6 <<= 8;
   myInts6 |= Wire.read ();
   myInts7 = Wire.read ();
   myInts7 <<= 8;
   myInts7 |= Wire.read ();
   myInts8 = Wire.read ();
   myInts8 <<= 8;
   myInts8 |= Wire.read ();
В последних четырех значениях билиберда.
Как изменить код. Подскажите?
